Old 14-04-2008, 22:57   #21 (permalink)
Frits
Some lowering blocks and 6 point Sabelt
Frits is offline   Reply With Quote
Old 15-04-2008, 14:32   #22 (permalink)
Frits
And the very nice datalogging steeringsensor, made from LEGO lol It (drift)works
Old 16-04-2008, 13:09   #23 (permalink)
FrictionAddiction
V.P.A. sprayer
FrictionAddiction's Avatar
Send a message via MSN to FrictionAddiction
dude i want your rear window louvre!! if ya find one on another one that you can get hold lemme know dude!! been looking for ages for one!! nice work too.
FrictionAddiction is offline   Reply With Quote
Old 16-04-2008, 13:21   #24 (permalink)
Frits
What you wan't to pay maximum for it? They sometimes appear on the dutch secondhand market, but they are not cheap. Payed €100 for mine.. And it is not 100% damagefree.
I'll let you know if I see any
Old 16-04-2008, 15:29   #25 (permalink)
FrictionAddiction
V.P.A. sprayer
deno really i will have to find out. but thanks for having a look if ya can dude!!! i have looked for one for ages!..... had one on one of my old cars. look well good.
Old 17-04-2008, 09:36   #26 (permalink)
Frits
i'll keep an eye out
Comming weekend three days drifting fun on dry, big event. People can drive with me, don't know or the really want to
8th of may round three. I hope for some good final position. I hope no understeer anymore with some brand new Bridgetstone front tires.
Old 21-04-2008, 22:28   #27 (permalink)
Frits
YouTube - Speed en Gein 2008
YouTube - speed en gein drift
Some drifting with the 340 on Speed en Gein event. But have broken the engine pretty bad
Old 21-04-2008, 23:02   #28 (permalink)
Dex
DoriDex Productions
Dex's Avatar
Send a message via MSN to Dex
shame it died! you were killing it! (literally :'()
Old 21-04-2008, 23:16   #29 (permalink)
Frits
Yes I killed it.. Just can't take the foot of the gas when having not enough power.. You guys all should have heard the revving engine.. lol
Some guys came to me, djeesz what rpm does it make..? I say, lol, not revvlimiter and lack of power does make rpm. Happy I don't have a rpm gauge, I would be scared.
Big problem for next round however... Can't imagen only the gasket died.
Old 21-04-2008, 23:18   #30 (permalink)
griffo20022
BMW Driver...
griffo20022's Avatar
Fair play to you Frits! Showing some of those big engine boys what it's all about! Ashame with the engine as Dex said! Although it's something you can take back, work on and make even stronger for next time!
Keep up the good work!
Old 22-04-2008, 16:04   #31 (permalink)
Frits
Ordered some stickers @ my sponsor, but forgot to make a "Can you beat a 1400cc" one lol
Probably a lot of work to fix the engine, but i'll just start fix it up!
Old 22-04-2008, 16:06   #32 (permalink)
Dex
DoriDex Productions
Dex's Avatar
b23 it!
Old 22-04-2008, 16:19   #33 (permalink)
Frits
Can't find the moneytrie
Old 25-04-2008, 12:52   #34 (permalink)
Frits
Full boost.....
Home build manifold
Broken cilinder!
Hope I can fix it before round 3, the 8th of may..
Old 25-04-2008, 12:55   #35 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
what boost was it hitting? stock liners are usually fine even at 30psi on stock compression if mapped well etc, but det makes cyl pressure go mental.
Old 25-04-2008, 13:27   #36 (permalink)
T.K
kudo fruiting
Map? Solex 32 DIS! You have to be pretty switched on to flash the AEI..
Got too hot I think.
T.K is offline   Reply With Quote
Old 25-04-2008, 14:34   #37 (permalink)
Frits
Normally driving 0.7 bar under butterfly.. But when the wastegate doesn't work.... Don't know what boost I was hitting, what does a OEM turbo gives? 1.3 bar or something..?
Carb isn't set up for that pressure..
I have heard detonation I think... It was pretty fast for a short time
Old 25-04-2008, 14:54   #38 (permalink)
T.K
kudo fruiting
OE turbo will boost plenty! You certainly deaded it.
Old 25-04-2008, 15:55   #39 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
You know what i meant. setup.
but yeah, det wouldve done that, normal cyl pressure alone wouldnt at only 1.3bar, the liners arnt mega strong as they wet ones, but they good for 2bar without too much trouble.
get it fixed and go for it mate, fairly cheap n easy at least.
Old 25-04-2008, 16:43   #40 (permalink)
Frits
Stavros, what do you think about this? Extreme hot exhaustvalve gets a load of water couse the cracking cilinder... valve bend? inner material change by quick cool down or whatever? Or nothing to worry about? just put the head back on?
Don't take the risk with the sparkplugs, they will be changed. But not sure about the exhaust valve.
