Old 05-03-2008, 11:51   #41 (permalink)
Eddy's Avatar
Why isnt this thread sticky?
Big respect for the team and their cars
Eddy is offline   Reply With Quote
Old 05-03-2008, 18:20   #42 (permalink)
IT GOIN' RAIN!
THICK SOUP's Avatar
Send a message via MSN to THICK SOUP
Was'nt this Skyline getting a RB30? Someone needs to stick a RB into something Toyota, just to even things out
__________________
THICK SOUP is offline   Reply With Quote
Old 05-03-2008, 18:36   #43 (permalink)
Resident Alco
Nelo's Avatar
Send a message via MSN to Nelo
Nice James. I suspect there was some reluctance to go Toyota with the engine but there's no denying in standard trim they're a far better engine unfortunately.. I suppose it took running Bon's car for a year to see it for yourselves
Best of luck with the rest of the conversion, sure to be sweet when done.
__________________
Nelo is offline   Reply With Quote
Old 05-03-2008, 19:58   #44 (permalink)
Road legal FTW
DoriDave's Avatar
So when are you guys gonna CA18 Bons beast? Tis only fair you all have Nissan/Toyota beasties!!!
__________________
Xbox Gamertag-DAVEDUDE1976
DoriDave is offline   Reply With Quote
Old 07-03-2008, 11:19   #45 (permalink)
Lights out!
James's Avatar
Nah, no reluctance at all. I'm happy to go with whatever works best
So, a quick update on some bits of progress, nothing too exciting, but each bit is a step closer to an awesome car so I'm all excited
Got some welding done locally as cast alloy welding is a right pain and I'm happy with the results
Turbo outlet now points in a useful direction
Welded up to point in the right direction. I've also blanked off the second turbo coolant feed.
Much better
Also sorted the bottom hose and changed the thermostat while I was there
__________________
The Driftworks Control System 2. In Stock Now!
Old 07-03-2008, 11:26   #46 (permalink)
Lights out!
James's Avatar
Out with all of this
Leaving everything pretty tidy and simple
Gearbox sat in the right place, but held up with a strap
New mount made up of part of the Toyota mount, a Nismo SR20 mount and a few extra bits of angle and strap. All welded up on number 6 by Mr Ant
Fits nicely and should be well strong
Looking at the fuel system, I wanted to run an external pressure reg and wasn't happy with the bore of the in and outputs of the rail, so Mr Steveo kindly sorted me out with a larger bore, more universal fitting for the rail.
That's it for the moment, but it's coming together nicely
The prop should be done by Monday and the VEMS is now ordered.
__________________
Old 07-03-2008, 11:37   #47 (permalink)
raff's Avatar
good work james where did ya get that manifold from?im hopiung your gona start stocking alot more ijz and 2jz stuff now!
raff is offline   Reply With Quote
Old 07-03-2008, 11:42   #48 (permalink)
Lights out!
James's Avatar
That was from eBay australia. Bit more expensive than the cheap ones, but not much and it sits the turbo in a nicer place so the exhaust shouldn't be that much of a pain to sort out.
And yeah, we'll start slowly introducing more Toyota bits to the range as the year goes on
__________________
Old 07-03-2008, 13:59   #49 (permalink)
RB30 Charger
David Reid's Avatar
Originally Posted by Phil View Post
They all died of heat basically. Melting pistons usually, and dropping a plug tip on the built engine. The actual component that killed the was me. I've been spoilt by the SR20 and the RB just can't handle the abuse of the SR.. Toyota power wins everytime anyway .
Phil I understand what your saying, but I cant see the material spec of an SR20 and Rb stock piston being different. Did you map them to the same EGT temp?
David Reid is offline   Reply With Quote
Old 07-03-2008, 18:55   #50 (permalink)
slingo's Avatar
awsome build james have you got any pictures of how you done the front engine mounts .
__________________
slingo is offline   Reply With Quote
Old 07-03-2008, 22:16   #51 (permalink)
Lights out!
James's Avatar
You can kind of see the mounts Steveo made in the middle of this picture
I used them, some SR20DET engine mounts and an S14 crossmember and it's sat the engine pretty much spot on. The S14 crossmember bolts straight up and sat the mounting position further back, which really helps meet the new mounts in the right place.
I need to get the whole lot out again this week to grind a rib on the sump down for better clearance and weld the mounts properly as they're only tacked at the minute so I'll get some better pictures then
__________________
Old 07-03-2008, 22:32   #52 (permalink)
Lights out!
James's Avatar
The 6 cylinder RB seems to generate a lot more heat under load than the SR20. Also part of the problem was that we hadn't planned for Phil to use the R32 so unlike the S14 with it's super efficient V-mount and big oil cooler setup, the Skyline just wasn't setup to shed the heat effectively
I feel most of our problems last year were down to being unlucky with problems like a failing oil pump, injectors that were flow tested ok but worked strangeley on the car and a couple of other silly bits and pieces. That highlighted to us that the RB engine seems great as long as it's totally happy and within it's set parameters, but the minute you step outside of those it's quite fragile whereas the JZ engines and to a lesser extent the SR20 appear a lot more strong and more robust.
__________________
Old 07-03-2008, 23:31   #53 (permalink)
calicagesracing's Avatar
cool project mate
good luck with it
calicagesracing is offline   Reply With Quote
Old 08-03-2008, 07:44   #54 (permalink)
TNS MAN CHILD
got a template so anyone who wants mounts PM me (plug ha ha)
__________________
EP Racing - Neo Oils - Managed technoliges - Turbo Dynamics - ITG Filters
Old 08-03-2008, 18:35   #55 (permalink)
Will_DW's Avatar
Looking awesome James, be good to you skid it!
__________________
r32 shell.. Got anything for me?
Originally Posted by Polo;
more manfoot and balls normaly sort this issue.
Old 09-03-2008, 20:06   #56 (permalink)
slingo's Avatar
il keep you in mind when my rb melts thanks james
__________________
Old 09-03-2008, 20:46   #57 (permalink)
DRIFT*DIVISION
NIcad7's Avatar
See...everyone wants a 1JZ, they are the ultimate engine for drifting, with regards to reliability, tuneabilty, and cost IMO. Oh and do i need to mention the sound they make?
Even that silly fast 700ps D1GP yellow onevia swapped from an RB26 to a
1JZ, cant remeber the drivers name though
Will be awesome James Good effort!
__________________
Old 10-03-2008, 17:58   #58 (permalink)
RWD Carless
EDnovaStarlet's Avatar
can't wait to see this car in action!
__________________
ED
Old 11-03-2008, 08:44   #59 (permalink)
The Yellow Onevia is driven my Kuroi
he didnt swap the 26 for a 1JZ
its a 2JZ
d1fury is offline   Reply With Quote
Old 11-03-2008, 22:50   #60 (permalink)
Greg's Avatar
Its actually a 1.5J
__________________
Greg is offline   Reply With Quote
Search this Thread:
Advanced Search
