Old 05-05-2008, 10:51   #1 (permalink)
swiftmini
Swiftmini's s13. new engine, thanks japimports.
Iam building my prefacelift 13 for road use and hopefully some drift practice days
I don't have much to report at the mo, although once the cometic headgasket arrives from PEC (Day 7 today, they are wank don't bother) i shall have it all back together ready for some practice.
Iam still in need of a slippy diff and a bucket.
The car has a locked rear subby, coillies, homebrew metal column spacer and possibly o few other bits that i have forgotten about.
Here is a few pics.
Cheers fellow skids
Will update as soon as i have the gasket.
Kev
swiftmini is offline   Reply With Quote
Old 05-05-2008, 10:55   #2 (permalink)
swiftmini
Td04 spools very well by the way. I think i may pick up a TD05 to try aswell.
I'm looking forward to running this up on the rollers
Kev
Old 05-05-2008, 17:33   #3 (permalink)
caged
Drift Gibbon
caged's Avatar
blimey - id like to see the inside of that elboW!
caged is offline   Reply With Quote
Old 05-05-2008, 18:30   #4 (permalink)
swiftmini
do you really? i'm gash at welding and the dump pipe needs altering.
I had a bash at a screamer job but couldn't get it too seal ok, sounded like a blowing exhaust.
kev
Old 23-05-2008, 06:42   #5 (permalink)
swiftmini
wooohoooo!
got it back on the road last night, i'm over the moon.
turbo makes 7 psi by about 2.5-3 k rpm, that's with actuator backed right off.
car is quick but its not quite alive enough, my suspicions are cam timing or maybe the cheap as chips chip.
got a few noises aswell now, a whining noise, probably diff whining through the locking collars.
also boost gauge making weird vibro/hiss noise.
got a rumbling clutch release bearing.
things that need attention are:-
turbo drain needs altering.
gearbox needs oil change.
need to turn my dampers down.
need to book rollers for a check up.
cheers
kev
Old 23-05-2008, 06:49   #6 (permalink)
swiftmini
almost forgot! I got z32 front callies and 310mm discs.
most of the 5 stud conversion
should have buckets and belts sorted by end of the w'end.
need to save for a slippy diff, so I can actually learn to drift. my skills are limited to gran turismo and local kart center.
cheers
kev
Old 23-05-2008, 09:08   #7 (permalink)
markturbo
markturbo's Avatar
alright mate,
which front mount kit is that? cheers
looking gd by the way
markturbo is offline   Reply With Quote
Old 24-05-2008, 01:26   #8 (permalink)
swiftmini
the fmic is an ebay job off a seller called autoextreme its an s13 sr20 kit so I have altered it slightly.
I picked up some buckets today, hope to fit them over the weekend.
also carried out the gearbox oil change (via shifter hole) and also engine oil and filter.
cheers
kev
Old 25-05-2008, 10:09   #9 (permalink)
swiftmini
I manage
198 miles before the inevitable happened.
blue smoke follewed by sluggishness and then loss of compression.
Gutted, all I want is to go drifting, grrrrr.
it could have happened after det or something, the engine hesitated and smoke went blue.
the car may get broken pending internal damage.
kev
Old 27-06-2008, 14:16   #10 (permalink)
swiftmini
well I now have an rb25det sat in the garage.
waiting for some more parts before I crack on with it.
to be honest it looks like it should be easy. lol.
we will see
kev
Old 27-06-2008, 15:23   #11 (permalink)
gaz_moose
.MTM.
just dont do any welding on it!!! lol
have you took your old engine apart to see what died?
Old 27-06-2008, 20:34   #12 (permalink)
swiftmini
Lol, yeah best not..
haven't pulled the motor out yet, not had time..
I'm pretty gutted bout it really, shouldn't have cut corners.
cheers
