18-07-2008, 11:37
| #122 (permalink) | |
| tail slider Join Date: Jul 2007
I have, Exhaust manifold dump valve rising rate fuel regulater 3.2 evo injectors a/c fan extra cooling turbosmart boost controller pipe work from intercooler to turbo I can get my pipe work coppied from inlet manifold to intercooler You would need to get a turbo td4 or similar and a intercooler. you could leave the standard compression and run it around 8/9 psi or put a thicker head gasket on(i might have one) and drop it to around 10.2.1. If you drop it i reckon you could run 14 psi and would give you well over 400bhp!!! I have run this setup on a 3.0 m3 engine with 10.2.1 compression and at 15 psi it give us 480bhp. If you wana have a go i will give you a hand. | |
01-08-2008, 22:32
| #129 (permalink) |
| ok no luck in sourcing turbo parts for it so looks like car will stay na for the short term future. sorry no updates me and alex at k drift have decided to do something a bit special and different with the car...watch this space |
