Old 02-06-2008, 00:21   #21 (permalink)
spin-king
spin-king's Avatar
Send a message via MSN to spin-king
Well just paid for my crystal type side indercaters buying the stuff for the frontend conversion while the bits come up at the right price.
Wont be changing the frontend till nextyear when i buy wider wings and a ps bonnet.
Will be chucking the 444 injectors and the spacers on this week i hope spacers are 30mm rears and 25 fronts
spin-king is offline   Reply With Quote
Old 03-06-2008, 23:01   #22 (permalink)
spin-king
spin-king's Avatar
Couple of pics not great and alittle chav like.
Managed to fit one bucket seat but the runners i got from tweeks are CRAP drivers side goes close needed modding to fit and the passenger ones agood 4mm out eachside so have one seat in the car at the min rear benches out too as i need wheel space plus saves asmall amount of weight.
Old 03-06-2008, 23:33   #23 (permalink)
mondo--drift
sweet car!!!
mondo--drift is offline   Reply With Quote
Old 06-06-2008, 15:47   #24 (permalink)
EDnovaStarlet
RWD Carless
EDnovaStarlet's Avatar
Nice P1 in the back ground!
Old 07-06-2008, 18:03   #25 (permalink)
spin-king
spin-king's Avatar
yer mates of mine looks ok but its 4x4 LOL
Anybody have anyidea what setting i should run my avcr on for drifting???
Mods are
Engine overhauled (new rings, shells, valves and pumps)
Nismo engine mounts
DB Brakes gearbox mount
Norris designs fmic and hard pipes
Norris designs stage 1 chip
T28 turbo
Apex performance turbo braided lines
Apexi super intake filter
Mongoose turbo back 70mm exhaust system
Samco hoses
HKS oil and rad caps
NGK grade 7 iridium plugs
Cometic 1.6mm headgasket
Apexi AVC-R boost controller
Greddy BOV
Viscous fan removed, 12" spal electric replacement.
Recored rad with uprated core.
Walbro fuel pump
Will have 444cc and manifold later on in june.
Its on setting
A .80
B 1.0
Been rr at 1.1 bar at 287 but the graph was all over the place since changed the faulty acuator.
Old 07-06-2008, 18:51   #26 (permalink)
griffo20022
BMW Driver...
griffo20022's Avatar
Looks a really nice car that dude
IMHO I personally think that bodykit will ruin the look of your car, it looks really tidy n sleeperish as it is and will look mega mint with the new front end. As long as you like it thats all that matters end of the day, its a really nice base car to work with
Old 07-06-2008, 22:52   #27 (permalink)
spin-king
spin-king's Avatar
Cheers mate BUT as i re-learn to drift i dont dont mind smashing the frontend up.
Once sorted and back to myself i will change the frontend to the sil80 as i have everything apart from the bonnet and with the sale of the carbon one i am buying will be able to sort that.
Anybody ot any idea's about the boost/avcr
Old 11-06-2008, 22:23   #28 (permalink)
spin-king
spin-king's Avatar
Went to pod today and get back into skidding was TURB to begin with but towards the end of the day had a go on the big track and was please with how it went.
Only issue i had with the car was it was getting close to over heating so took the bonnet off and a rear subframe bush died so solid once to come.
Also need to fit these bits
Lights are for the frontend conversion nextyear.
welded diff
Pullies
skyline rear calipers
PS lights
seats in and rear stripped
And couple of random ones of the car
Old 12-06-2008, 17:28   #29 (permalink)
spin-king
spin-king's Avatar
Once my old 200's out the garage i'll start work on this putting the bits on i have bought.
Couple if better pics of the car and the leaking bush and the dirty scratch some little tit has done on the bonnet
Old 12-06-2008, 21:23   #30 (permalink)
stueywalls1
stueywalls1's Avatar
Tony mate it needs lowering a bit more. I will hopefully be getting the shell back off you on the 28th if everything goes ok down here. 3 weeks of 20 hour days are not good without a day off.
stueywalls1 is offline   Reply With Quote
Old 12-06-2008, 21:34   #31 (permalink)
spin-king
spin-king's Avatar
Have to keep it that high at the min cos of the bloody speed bumps in the road once its garaged (not digging) i'll put it on its arse
Old 13-06-2008, 20:58   #32 (permalink)
spin-king
spin-king's Avatar
Pics of my skidding for a change
Old 17-06-2008, 16:52   #33 (permalink)
spin-king
spin-king's Avatar
Got my sil80/ps13 sidlights in crystal verynice have everything i need to do the frontend change but will be getting more skidding time untill i change it.
Car needs to go lower though just waiting to order the rear bottom arms and i'll do everything at once tein rods and ends and set it up for drifting
Front:
-2.5 camber
7.5 degrees caster
0 toe
Rear:
-1 camber
2mm toe in
Will also widen the track of the car.
Old 29-06-2008, 22:09   #34 (permalink)
spin-king
spin-king's Avatar
Next for the car and to be ordered this week are
apex rad
11" fan
50mm spacers
and poss wider finders for the car to go with
Solid subframe bushes
My new rps clutch and sweet wide wheels (worthy))
Cars off the bodyshop for the kit to be sprayed and fitted and the rust sorted.
Also off the pod on the 9th of july hoping to have most bits fitted by then LOL
Old 29-06-2008, 22:14   #35 (permalink)
bell
MATT DAMON!!
bell's Avatar
looking bad mate
you skidding in july then?
and would that manifold be off mr mash?
bell is offline   Reply With Quote
Old 29-06-2008, 22:23   #36 (permalink)
spin-king
spin-king's Avatar
Yer paying asoon as my wages go in tonight at midnight LOL
Manifold was off dori mat.
Whys it looking bad (guess you have seen my spanner work )
Old 29-06-2008, 22:33   #37 (permalink)
bell
MATT DAMON!!
bell's Avatar
bad as in good haha
ahhh thought i recognised it as someone elses but also thought i had never seen your car at the last dwyb i was at
shall seeya there then mate
Old 29-06-2008, 22:33   #38 (permalink)
driftnething
driftnething's Avatar
awsome car engine looks very nice !
Old 29-06-2008, 22:37   #39 (permalink)
spin-king
spin-king's Avatar
Originally Posted by bell View Post
bad as in good haha
was at the lastone see pics ^^^^^^
Have been to loads with my mate who has red s14 white front wheels just been taking photo's i know but playing GAIN myself now
You going and if so what you in???
driftnething cheers but cant take credit as turbo toms old car and he did most of the work i am just making the car better then he made it LOL
Old 30-06-2008, 22:56   #40 (permalink)
spin-king
spin-king's Avatar
Bought myself some SWEEEEEEEEET RIMS
18" rota gtr's 8.5 fronts and 9.5 rears will be getting 215/40/18's and 225/40/18's on them.
Cant wait to get them as i love these wheels.
Also bought a new clutch its a RPS MAX PUCK
