Old 18-06-2008, 12:31   #21 (permalink)
Jill
Jill's Avatar
Ohh I want a AE86 too... This tread shall I follow
Jill is offline   Reply With Quote
Old 18-06-2008, 18:30   #22 (permalink)
Kruizer
Kruizer's Avatar
The colour is like marmite, you either love it or you hate it
Car will be going over to Dancoirl next week hopefully and I should have an update from there...
Kruizer is offline   Reply With Quote
Old 21-06-2008, 01:59   #23 (permalink)
Kruizer
Kruizer's Avatar
Got an old superlite off the starlet and threw white paint at it. So what ya think change the wheels to white from black ? By the way the black on the rear is 15" x 7" and the front is 13" x 7"
Old 21-06-2008, 02:07   #24 (permalink)
GreenMachine
GreenMachine's Avatar
hard to tell man..
From the pics i'd say keep black, but I would favour a load of different wheels that'd suit that car:
Work Equip 01s
" "" 03s
Work Meister S1s (like on mine)
Volk racing mesh (atleast 8.5j and 14s)
XR4 longchamps
GreenMachine is offline   Reply With Quote
Old 21-06-2008, 02:18   #25 (permalink)
Kruizer
Kruizer's Avatar
I have a set of SSR Longchamps XR4's already lad.
Old 21-06-2008, 02:38   #26 (permalink)
KRae86
KRae86's Avatar
wheels
id go for a really deep set of watanabes in graphite mayb??plz don put 13inch superlites on it too many cool jap cams have bin ruined over here with em sweet car lovin the mad green
KRae86 is offline   Reply With Quote
Old 21-06-2008, 02:55   #27 (permalink)
Kruizer
Kruizer's Avatar
Don't kill me but its actually a UK Spec Coupe that was stripped and rebuilt into what you see now !
Old 21-06-2008, 03:36   #28 (permalink)
GreenMachine
Tis the lock on the fuel cap and wing sidelights that give that away.. don't think any japs come with those.
Any pics of the XR4s on it?? what size/width and offset?
Old 21-06-2008, 09:40   #29 (permalink)
retrodan
smashes aero
retrodan's Avatar
could sware that looks like frenchy's garage lol
car looks good dude, have u driven her yet? as black tops are very good engine, but one thing get rid of them weak intake stacks and order some T3 ones from america, as they longer, wider, smoother and oh look ALOT better than them ones fitted!!!
Old 21-06-2008, 09:52   #30 (permalink)
VrtasCZ
VrtasCZ's Avatar
Send a message via ICQ to VrtasCZ Send a message via MSN to VrtasCZ
Sweet Hachi
VrtasCZ is offline   Reply With Quote
Old 23-06-2008, 19:15   #31 (permalink)
Kruizer
Kruizer's Avatar
No pic's of the xr4's yet martin, 2 are on the starlet and 2 are in my garage...
@ Retrodan : I wish lad Nope, haven't done any rings yet, had her a few weeks but like i said i wanna get the few bits sorted first and then I'll make up for lost time
Thanks VrtasCZ
Old 23-06-2008, 19:29   #32 (permalink)
jap-si
TE37 club
jap-si's Avatar
13" don't look right with all the kit on there. if you don't like the 15" get some 14. still nice and small without being lost in there.
those xr4 are going to need to be wide as hell if you fit cby arches. no + offset nor anything under 8.5j.
jap-si is offline   Reply With Quote
Old 23-06-2008, 19:54   #33 (permalink)
Kruizer
Kruizer's Avatar
Can you explain offset ? + / - etc... Never got it nor did I ever ask for an explanation of it... Would be handy as I've to get new wheels for the RX7 also...
Old 23-06-2008, 22:42   #34 (permalink)
jap-si
TE37 club
jap-si's Avatar
to avoid over technical explanation it's the dish you got. the 15"s you got have a high offset and no dish, the wheels you need to fill CBY will have to be low offset.
here is an example
wheels + manifold
the first are high offset (+30mm) the second set are lowwer offset (-2mm)
http://www.driftworks.com/resources/...ulator,17.html
Old 23-06-2008, 22:49   #35 (permalink)
Kruizer
Kruizer's Avatar
So if you wanted you could go to a -20 offset for a huge dish but the wheel would have to be very wide ?
Thanking you by the way
Old 24-06-2008, 09:38   #36 (permalink)
jap-si
TE37 club
jap-si's Avatar
imagine a 6j wheel. and it has a -+0 offset. the back face that mounts to the hub would be in the center line of the wheel.
6j -30 would mean that same mounting face was 30mm toward the back of the wheel effectily pushing the wheel further out of the arch.
6j +30 would mean the same mouning face would be pushed to the front of the wheel. making for very little dish if any.
7j with -+0 or -30 or +30 will not sit in the same place as the 6j. so beware do some good research before you wreck your cam with CBY arches.
it's very rare that somone actually makes them CBY look good with the right wheels. if you put CBY arches and superlites on there they would never be seen again.
search out offset on the net there are loads of better explanations.
Old 24-06-2008, 13:56   #37 (permalink)
GreenMachine
Possibly one of the best way someone can describe offset to people!!
Old 24-06-2008, 14:10   #38 (permalink)
jap-si
TE37 club
jap-si's Avatar
shamlessly stolen.
Here's the basic specs on the CBY fender flares and what wheel size/offsets they are using on their demo Levin.
Flares:
Front: 50mm / 1.97 inches
Rear: 65mm / 2.56 inches
Wheels:
Panasport C8R
Front: 16x9.0" -6 offset
Rear: 16x9.0" -43 offset
Tire: 225/45-16 all around
Front Lower Arm extended 35mm
basically don't go CBY unless you got a big wallet for the rims you will need.
Old 24-06-2008, 17:50   #39 (permalink)
Kruizer
Kruizer's Avatar
I take it you don't rate spacers then Cheers for all you help man, tis much appreciated, must start looking for wheels now. CBY Arches are on their way from JDM Parts, JDM Racing Accessories, Twin Plate Clutch, Turbo Kit, Fuel Injectors & other Motor Parts! Ordered them Saturday.
Old 24-06-2008, 18:34   #40 (permalink)
jap-si
TE37 club
jap-si's Avatar
you can use spacers but, you will need big ones.
