06-07-2008, 20:25
| Frontyard Join Date: Apr 2007 Location: ub1 3aj
| f.y.e s14a mark II been working on this project for a while now and is coming together nicely, it was bought as a straight swap for a black gts skyline r33 id say the s14a my mate got in return was the better car as the body and engine was and still is mint, has alot of goodies and the f.y.e colour theme sprayed a week ago to the inside s/s tubular manifold ![]() hks mushroom for better breathing ![]() front and rear struts painted with the tien style paint scheme out of coinsidence ![]() ![]() ![]() subframe stripped and painted candy green and now fitted with solid sub bushes and dift bushes from apex ![]() ![]() first went on was a coat of sparkley silver ![]() then 3 coats of candy green so when the sun light hits the paint you can really see the shine of the silver giving it that 3-d effect ![]() same thing was done to the cam cover ![]() ![]() ![]() ![]() i think polo welded the dif a little while back ![]() ![]() ![]() inside striped to bare metal and painted ![]() ![]() ![]() the rear shelf also grind off ![]() full turbo back zaust system ![]() carbon hood ![]() this s14a will be running the garrett gt2871r internal wastegate b/b turbo set up to see how well it does against the greddy td-06 topmount external wastegate setup ![]() can you geuss which ones f.y.e mark I and which ones f.y.e mark II ![]() ![]() |
10-08-2008, 00:31
| #18 (permalink) |
| after a long long long time finally got round to this one been to busy on other sx's man i wish i can spend all my efforts on the cars that really do matter ![]() used a bit of gunk cleaner to clean the k sport coilovers which saqib left at the garage it really restored the suspensions nicely, bling bling just like new ![]() ![]() the subframes finally complete with all the arms, 300zx rear brake setup fitted and solid bushes ![]() ![]() ![]() ![]() subframe on the car ![]() ![]() 52mm rad fitted ![]() |
