Old 19-07-2008, 13:12   #1 (permalink)
RoCo-Per4mance
RoCo-Per4mance's Avatar
RoCo Performance 2nd f20c ae86 conversion
well lads and lassies, just thaught id throw up a few pics of the latest build in the work shop, with our suscess with conor's s2000 ae86 we were asked to swap another f20c into a ae86 for a customer. the only twist is that its going to be a road car. so we couldnt go as low as conors, so every dimension we had worked out for conors car was scraped, and we started at the start.
what we were given
f20c
RoCo-Per4mance is offline   Reply With Quote
Old 19-07-2008, 13:25   #2 (permalink)
RoCo-Per4mance
first thing was to line up the engine and cut the tunnel. i love cutting up perfectly good cars.!! once we had that done we fabricated up the cross member,
we used mk2 escort engine mounts as the s2k ones were shot.
after we had the engine sitting where we wanted, we made a frame for the new tunnel. this gives a bit of rigidity to the bulkhead and tunnel.
we then fabricated the new tunnel out of sheet metal
Old 19-07-2008, 13:35   #3 (permalink)
RoCo-Per4mance
we then primed and painted the new tunnel.
as this is going to be a road car, we had to keep ground clearance as high as possible, but also place the engine appropriately for handling. we sat the engine as close to the bulkhead as posible, and we cut through the crossmember to lower the engine into it. by doing this the engine sits low in the bay, but still high off the ground.
Old 19-07-2008, 13:50   #4 (permalink)
RoCo-Per4mance
so now were most of the way through the swap but not out of hot water yet.
we now have the engine mounted, and sitting prety, the bulkhead is fabed and painted, and engine height and position is set. the customer asked us to modifie the stock manifold like we did for conor as he couldnt find anyone to build one on short notice. so heres the engine in place,
and this is the space we have to work with! not much
with the position of this engine, we had a bit more room than with conors build, as the engine is 10mm more forward. 10mm is alot.
we mocked up a jig and made the primary's fit down into the tiny gap between
the chasis leg and the steering rack.
Old 19-07-2008, 13:59   #5 (permalink)
RoCo-Per4mance
the gap between the leg and the manifold.
the gap between the rack and the manifold
we then took measurements and made a jig for the secondary tubes.
took the primarys back out and then made the full manifold.
we then ported and ground all welds, and cleand it up.
Old 19-07-2008, 14:07   #6 (permalink)
RoCo-Per4mance
after that we just bolted it all back together, and we had another f20ae86
this is all the customer wanted us to do, he is finishing the wiring and the rest of the cosmetics, if i get any more pics and any update on this build ill post her up.
Old 20-07-2008, 17:24   #7 (permalink)
wallycam
wallycam's Avatar
wat kinda money would ya be talkin up to tat point of the build
wallycam is offline   Reply With Quote
Old 20-07-2008, 17:46   #8 (permalink)
Ian.G
86 ColdTurkey
Ian.G's Avatar
Send a message via MSN to Ian.G
Jesus...you are bangin em out now man
Ian.G is offline   Reply With Quote
Old 20-07-2008, 18:32   #9 (permalink)
jap scrap
jap scrap's Avatar
Not bad for 1 days work tidy work lads where is the best place to buy a s2000 engine and box
jap scrap is offline   Reply With Quote
Old 20-07-2008, 21:17   #10 (permalink)
Garyowens
You could try icetronix but it wont be cheap.
Garyowens is offline   Reply With Quote
Old 20-07-2008, 21:21   #11 (permalink)
RoCo-Per4mance
thanks guys,
@ ian. ah yea man were just doin our best, hows your beast lookin,?
@jap scrap. not too sure man, full engine and box from england for about 3.5-4k, either that or off a jdm engine importer,? price usualy depends on age milage, etc.
Old 20-07-2008, 23:50   #12 (permalink)
yellowevo
i have a s2000 engine n box for sale .Also have jenvey throttle bodies,cat cams and dta management for sale.Im in the orth 07740305324
yellowevo is offline   Reply With Quote
Old 21-07-2008, 08:10   #13 (permalink)
Xaerobbo
Good work, very impressive
Xaerobbo is offline   Reply With Quote
Old 21-07-2008, 13:31   #14 (permalink)
RoCo-Per4mance
thanks, always nice to see your hard work appreciated.
