Old 17-08-2008, 21:50   #21 (permalink)
robrs2
Ref: Cage. The 3 door and saff or 5 door have the same floor pan. So to feet of the cages are the same. The main hoop should be in the same place as there normaly positioned in relation to the drivers seat, although 4 door ones are sometimes further forward ? don't know why.
The main difference is the height of the cage due to the sunroof, but the sunroof runners can be cut off the roof to fit a non sunroof cage.
Some 3 door cages are hard to fit in a 4 door shell though if they have X bars in.
Mart, Nice work on the sound shit. Mine is still on.
Old 18-08-2008, 07:04   #22 (permalink)
WelshMart
WelshMart's Avatar
More stripping on Sunday, as I'm using all my old stuff I'm giving the front cross member and rear subframe back to Tom
So now everything is stripped it time to start rebuilding, first on the list is to break out the trusty welder, there's a patch on the passenger side of the transmition tunnel that needs patching and this inner sill to floor have atarted to go in a few places inside, I've also got a few unwanted holes in the bulk head that the BDC reg require me to block up....
WelshMart is offline   Reply With Quote
Old 02-09-2008, 18:12   #23 (permalink)
WelshMart
WelshMart's Avatar
Sorry for the lack of updates recently but the weather has been crap in derby and progress has been slow.
Managed to get some stuff done most of last week involved cleaning the engine bay, btw cheap ass washing up liquid is great for cleaning off all the grime and oil in the engine bay, I also managed to prep the rusty areas, mainly by chopping out the big pieces and treating the smaller patches with rust treatment.
On the weekend I got the welder out:
Patched the inner sills where they had started to rust away
Also the passenger side rear outer seat mount needed some work
The transmittion tunnel on the passenger side had rusted through
I patched this underneath with 3mm plate where it had gone through the double skin and it was near the gearbox mount then dressed it inside. Debating if I should drill some hole anf plug weld them together, but doubt it'll really add strength.
Also cout out the old handbrake mount to make a nice flat section to mount the hydro, used 3mm plate again to make it nice and strong
As I'm not gonna be running heaters in the car I had some holes in the bulkhead to patch some fire cant get through them
Then I got bored of welding, I've decided to try and save weight at the front I'm gonna make a box section front end which will have a removeable part to aid installing and removing the engine and also have a radiator protector built in to save me from those nasty cones so I took the angle grinder to it.....
Weather was shit on Monday nite but I got home from work today and the sun was out so I set about making a rear firewall so that I can install a boot mounted fuel tank, I ended up with this before it poured down
Dont be too harsh with my welding skills I know they aint great but I still got my L plates and trust me the inner sills in the sierra are like paper, I'm getting better I think...
Old 02-09-2008, 18:27   #24 (permalink)
chunk
sucks
chunk's Avatar
Big hats off to you Mart. Your doing a top job dude.
I'll try to pop over and have a nosey on day soon
Old 02-09-2008, 18:30   #25 (permalink)
Silverfang
No longer K1
That's not bad welding considering, Mine's not much better to be honest But looks like you've got good penitration there (oo er!)
I found easing back on the wire helps avoid too much weld build up and if you 'swirl' the weld pool it knits the metal together rather well if you can get it going.
Sides that, looking really good there so far
Old 02-09-2008, 19:01   #26 (permalink)
WelshMart
WelshMart's Avatar
Cheers guys, it the first time I've let loose with the welder on my own so a lot of it was learning as I go. Its not too bad but certainly not upto pro standards, I'll get grinding a bit more to flat the welds back a bit and neaten them up a bit but I'm happy with them so far and I've learnt a lot.
Chunk pop over whenever you're free always welcome dude
Old 02-09-2008, 23:30   #27 (permalink)
rsturboboy
what u on with Mart the weather has been brill ........
rsturboboy is offline   Reply With Quote
Old 22-09-2008, 18:01   #28 (permalink)
WelshMart
WelshMart's Avatar
Right another update for you, things are still going slow what with the Derby weather recently and the need to use power tools outdoors but work is carrying on when I get chance out there.
In the last couple of weeks I have cut out the spare wheel well and welded in a sheet to cover the hole and give me somewhere to mount my new shiny fuel cell
I have sprayed the boot black, well most of it the rest I couldn't do without getting gassed
I have cut the structure out of the boot to save some more weight
and I have put bonnet pins on the boot to make it accessable without a key as the rules of BDC state
I have also fixed the drivers side electric window which had come off its runners and I have cut out the sunroof and replaced it with a sheet of metal
Tonight I started to construct the box section front end that i am making but rain stopped play after I had tacked the uprights in and the new headlamp suround on one side in so hopefully a drier night tomorrow for me to finish that.
Old 22-09-2008, 21:50   #29 (permalink)
NikDev
Drifts a Swede
NikDev's Avatar
Real nice construction work there! But is spot welding enough? On both firewall and boot?
NikDev is offline   Reply With Quote
Old 23-09-2008, 00:13   #30 (permalink)
topi
KlutchKickKidz
topi's Avatar
Yep!
Old 23-09-2008, 09:02   #31 (permalink)
WelshMart
WelshMart's Avatar
Neither the boot floor nor the firewall are structural so spot weldswill be fine
Old 23-09-2008, 09:21   #32 (permalink)
Jeek™
www.TrampDrift.com
Nice work mart! you could have saved a bundle and just bought mines!
Jeek™ is offline   Reply With Quote
Old 23-09-2008, 10:10   #33 (permalink)
WelshMart
WelshMart's Avatar
I couldn't have got enough of the money back out of my old car to afford yours, plus I'm learning a lot whilst I build and applying things that i learnt last time and seeing them work so I'm finding it quite satisfying..
Old 23-09-2008, 10:25   #34 (permalink)
Quail
Kouki Monster
Quail's Avatar
Send a message via MSN to Quail
This is a really nice build. Keep up the good work
Quail is offline   Reply With Quote
Old 23-09-2008, 19:12   #35 (permalink)
WelshMart
WelshMart's Avatar
Finally I get a dry nite to break the welder out properly, so I set about making the box section front end
Some pictures of my welds, camera kept wanting to focus on other things though.
And here is the finished article
And doing what its made to do
Protecting the radiator which is in a fragile place, I'm happy with it and it looks pretty tidy too
Old 23-09-2008, 19:59   #36 (permalink)
Corey_XR4I
XR4I 24V FTW
Corey_XR4I's Avatar
Thats awsome m8, so erm.... when you doing mine?
Corey_XR4I is online now   Reply With Quote
Old 24-09-2008, 09:33   #37 (permalink)
WelshMart
WelshMart's Avatar
When you bring me your car, some metal and some money to pay for my skils, lol
Old 24-09-2008, 18:46   #38 (permalink)
Corey_XR4I
XR4I 24V FTW
Corey_XR4I's Avatar
Ha, i ideally need two new inner and outer cills and one new rear arches off where i crashhhuuuu into garage door doh!
a lad near mine is coming to do them cheap i believe so all is good, very impressed with your skills tho m8 very nice
Old 25-09-2008, 19:41   #39 (permalink)
WelshMart
WelshMart's Avatar
I've had another hard evenings work, the pull cables are mounted
the bonnet is pinned
and the big holes in the rear shelf are covered
Here's the trailer full of scrap metal that I have cut out of the shell
That means that most of the welding is done, leaving me now with some tidying up to do, painting the interior, painting the engine bay, refitting the loom and dash etc.
Hopefully in the next few weeks I should start seeing it all coming back together and looking less and less like a bare shell on my drive and more like a car again.
Old 25-09-2008, 23:00   #40 (permalink)
robrs2
Some extreme work there Mart. Are you going to tie the cage into the front inner wings?
