01-07-2009, 17:06
| #102 (permalink) |
| spl dori master |
Yes mate that would be amazing if you could, are they for the rear? Also someone from the chevette owners group says he would like to contact you for info on your engine etc. his email is ianocon@hotmail.com If you could let us know about theose springs that would be great. Thanks again |
18-07-2009, 13:53
| #114 (permalink) |
| spl dori master |
Ill try and fine it out for you mate but its on the car now. All I know is a manta box will fit, also the carlton box will fit and the stud pattern is the same accross the whole range. Whether it being the old 8v or the redtop 16v. I'll do a bit more research for you though but the best thing to do would be to buy a gasket from ebay
19-07-2009, 22:32
| #116 (permalink) |
| spl dori master |
I have home made mounts. I used omega/carlton engine mounting rubbers and then homemade mounts. There pretty simple really just get the engine sat where you want it on a crane then make a cardboard template then make them out of steel. these are the rubbers i used. they thread into the original chevette mounting points. you just have to grind the tabs of them |
21-07-2009, 16:22
| #118 (permalink) |
| spl dori master |
wooo won a Manta axle on eBay so just need to get it to my house now. Its in eastleigh, hampshire and im from Macclesfield, south manchester. My car has a snapped halfshaft which is the reason for this axle. anyone coming up this way from down south soon or got any ideas on how to collect it?
