Had this since 2006 and gradually been building it since then when it was fairly standard. Have got it more respectable over christmas presentation wise as this wasnt high on the list of agendas before. Done loads of trackdays in it while slowly upgrading parts to my liking. Have also changed the coilovers to the CS2 ones over winter which in provisional road testing have proved far more controlled than what i was running before, so i am looking forward to trying these out this year also
Heres the spec:
Engine:
FMIC
2871r 0.64 BB turbo+ HKS actuator
Braided turbo lines
Z32 MAF
Tomei exhaust manifold
blitz boost controller
greddy big winged and baffled sump
Apexi intake filter
fujitsubo system 3in turbo back
oil catch tank
greddy blowoff
6 puk RPS paddle clutch
4.5kg Cyn R G segmented flywheel
stock gbox 3rd one
gbox poly mounted
cusco engine mounts
walbro fuel pump
koyo radiator
mocal oil cooler with filter relocation kit
rocker arm stoppers
At 1.35bar:
power- 333bhp
torque- 340lb/ft
Electronics:
Apexi Power FC standalone ECU plus commander mapped by H-Dev
Blitz DSBC boost controller
Suspension:
DW CS2 coilovers 8/6 kg/mm spring ratings
top mounts adjustable
rose jointed DW tension arms
rose jointed DW front lower arms
Z33 tein steering arms with SPL anti bump steer rod ends
rose jointed DW rear traction arms
rose jointed DW rear toe arms
rose jointed DW rear camber arms
rose jointed DW rear lower arms
largus d1 arbs front and rear
rear subrame locked
Diff locked on subframe
nismo gt pro 2 way adjustable lsd
Brakes and Wheels:
325mm front r33 gtr brembos with PF 2 piece rptors
305mm rear r33 gtr brembos
Performance friction PF01 compound pads all round
r33 gtr servo and master cylinder
Castrol SRF brake fluid
Inline wilwod hydro ebrake
Inline wilwood brake bias valve just prior to ebrake M/C
17 by 9j wedsport alloys
235/40 toyo R888s
Interior:
stripped+chequerplates on floor+padding
6 pt cage with door bars fabricage bolt in
Custom carbon door cards/covers
Recaro Profi-SPG seats
driftworks 3in 4 pt harness driver
sabelt 2 in 4 pt harness Passenger
sparco wheel
didlo knob
boost gauge
water temp gauge
plumbed in extinguisher and cut-off switches
Exterior:
Stock Silvia Ks bodykit from factory
bumper cutout at front for cooling
spoiler deleted
Seibon carbon doors
chargespeed carbon bonnet aerocatch
Black
weight:
1160kgs no fuel or passengers
Some pics:
was lapping in the late 7s btg at the ring last time out in august on the t28, hoping to go lower this year. Heading out this weekend to test the new turbo and coilover setup cant wait!
wish me good luck with the weather!
LinkBack URL
About LinkBacks
Hope to get out in May for a short one, maybe for the DTM Revival..
