Results 1 to 16 of 16
    Banned
    Jun 2011
    27
    i need some info on alloys for my mk4 supra that will go over uk calipers
    hi
    im looking to buy some alloys for my supra in 18inch staggered but im not too sure what is the maximum offset i can use... iv been told its 5x114.38
    the wheels need to clear the front calipers as they are uk spec
    and the suspension is standard
    any idea guys?
    or if you guys have anything for sale that would fit
    or pictures of wot would look good without rolling the arches and messing with the suspension
    LOOSE!
    Apr 2010
    Welwyn
    1,368
    Hi, you don't seem to have any idea what you are talking about.
    5x114.3 is the PCD - the stud pattern.
    The offset is a positive or negative number which describes the distance between the position of the centerline of the wheel and the mounting face (the bit that sits flat on the hub when you bolt it up).
    Quote Originally Posted by kashamin View Post
    Is that supposed to be 5x114 +38? I dont know about wheel fitment on a supra, there are a few supra owners knocking about here though. All I know is that supra arches look massive, so you should have plenty of room to play with.
    PS13 K's x LOOSE
    UP ALL NIGHT GOT DEMONS TO FIGHT
    Nov 2007
    1,749
    Quote Originally Posted by Ollie View Post
    lol, tell it like it is
    Width is also going to play a part, if they're pony 18x7 wheels arch rubbing is unlikely to be an issue.
    Also generally you want the lowest offset you can, not the highest - generally lower offset looks better
    What are the specs of the wheel? It should be listed something like this:
    18x8J + 30
    Size X Width + offset (occasionally you can get negative offset wheels)
  4. #4
    Feb 2006
    Lincoln
    2,020
    Thing with the UK brakes, offset isnt really important but the design of the wheel is.
  5. #5
    Banned
    Jun 2011
    27
    cheers ollie
  6. #6
    Banned
    Jun 2011
    27
    .....so if i use set of 18's with 8.5 front rear 9.5j and offset 28 would that cause any problems like tyres rubbing on the arches...or other problems that you folks may know of?
  7. #7
    LOOSE!
    Apr 2010
    Welwyn
    1,368
    Wheel Fitment & Question Thread
    Try here, seems pretty explanatory.
    PS13 K's x LOOSE
  8. #8
    UK ODC Driver 78
    Oct 2007
    Swadlincote, Derbyshire
    1,674
    doubt 18's will rub your arches if your suspension is standard, unless you run 4x4 tyres.. the issue you may have is wheel protruding from the arch which is technically illegal (no matter what the vdub boys say) but again, thats all down to the offset of the wheel
  9. #9
    Banned
    Jun 2011
    27
    vertec manaray sports VR5 18" 5x114 drift 200sx deep dish | eBay
    do you think these should clear the uk brakes on my supra...nasty colour i know
  10. #10
    LOOSE!
    Apr 2010
    Welwyn
    1,368
    probably, google wheel offset calculator or something.
    Be careful though, someones painted those wheels a shit colour and they have "smell" marks on the lips, which sounds like skiddies.
    PS13 K's x LOOSE
  11. #11
    Feb 2006
    Lincoln
    2,020
    Probably not, fairly flat centres, low offset.
  12. #12
    Banned
    Jun 2011
    27
    well guys if you can choose somthing nice for me as i want a drift look with a dish to suit a gun metal supra mk4 my budget is £500 with tyres...i may able to squeeze in £600 but only if the rims and tyres look the best...and it must have a wow factor
    and to be honest its my 1st time buying rims and there is so much to choose from....i want my wheels out of the arch as possible without lowering the car and hopefully without rolling the arches so plllllllsss help me out with your ideas and imagination
  13. #13
    DWYB & DRIFT TAXI
    Aug 2004
    Bucks
    2,155
    To start with I think you'll have to double your budget just for the rims with out tyres.
    take a look in the for sale section to see what decent make/model ,sizes and offset, dishy wheels go for
  14. #14
    Feb 2006
    Lincoln
    2,020
    Get on MKIV.net, all the knowledge you would ever need is there.
    Ive had a few cars with UK specs on, one of my Soarers had UKs and ran Advan RG IIs, +35 offset but a heavily curved spoke design. My Aristo has UK's currently and a pair of Do Luck Double 6s clear them. It used to have SSR Leon Hardiritts (very similar to Work Equips) which were either 0 or very low offset but they needed a spacer to clear the caliper.
  15. #15
    Banned
    Jun 2011
    27
    Quote Originally Posted by Swampy442 View Post
    alloy wheels with tyres supra bmw rxz 350z etc | eBay
    would these babies fit??
  16. #16
    Feb 2012
    Luton
    165
    Not a fucking chance. Cheap shit wheels with piss poor clearance.
    As said, get on the supra forum and see what wheels others have fitted, that way you can also see what wheels look best.
