Old 06-06-2008, 13:56   #1 (permalink)
M@r]{
M@r]{'s Avatar
Send a message via MSN to M@r]{
Can you convert a DashDodger cage in BDC/EDC spec?
If a car has a dash dodger cage, can it be modifed to be EDC/BDC spec or wil I just have to rip it out and get a proper cage?
M@r]{ is offline   Reply With Quote
Old 06-06-2008, 14:06   #2 (permalink)
Brunosr13
Brunosr13's Avatar
Rip out and get proper one
Brunosr13 is offline   Reply With Quote
Old 06-06-2008, 14:50   #3 (permalink)
manfoot
TEAM GREEN
manfoot's Avatar
if the main hoop is the carrect size you can change the cage to a trogh dash i believe
manfoot is offline   Reply With Quote
Old 06-06-2008, 19:00   #4 (permalink)
sx-si
if the main hoop is the "correct" size, then you can change the cage too a through dash
if the rest of the cage is good enough for bdc/edc then you can get it adapted
sx-si is offline   Reply With Quote
Old 06-06-2008, 19:01   #5 (permalink)
e30 of Death
If it only bolts together (as I suspect) then yeah just pull the front legs off and get new ones made at fabricage/chizfab/clarkey/k-drift etc. But no point if the rest is too thin tube etc.
Old 06-06-2008, 20:08   #6 (permalink)
Jimthejunior
Represent
Jimthejunior's Avatar
What do you class as a "dash dogder". There are two types that could be called "dash dogders". One is illegal one is legal. Iirc mitch had the second type in one of his s13's.
Old 06-06-2008, 20:18   #7 (permalink)
Mitch
GRDriftGarage
Mitch's Avatar
The dash dodger most speak of are the ones with the bend around the dash. The one I had (and that you can use for comps) are ones that go in front of the dash but straight downwards.
Old 06-06-2008, 21:58   #8 (permalink)
cromwell
needs a car!
cromwell's Avatar
thats the dash dodger that was in my last 33. the front legs on mine unbolted at the roof and i could have put new ones in that went straight down to the floor (through the dash), im assuming yours is about the same?
cromwell is offline   Reply With Quote
