09-07-2008, 23:17
| #22 (permalink) |
| tail slider Join Date: Dec 2007 Location: wexford, ireland
| heres mine!! LEVEL: Pro (ireland) CAR: Nissan 180sx, sr20det EXTERIOR: *Uras S15 front bumper *Origin S15 +30mm front fenders *Custom fiberglass s15 bonnet *fiberglass s15 light covers *Ganador mirrors *uras 180sx side skirs and rear bumper *+50 mm rear overfenders *Buddy club Highrise carbon spoiler *Koki rear lights *polycarbonate rear screen *sprayed in ferrari red *rear metal quaters removed under overfenders *Front and rear archs tubbed for extra clearance *Fully seamwelded *Boot floor replaced INTERIOR: *Prodrive WRC seats x2 *D2 harnesses *Timex guages *Full weld in 18pt cage *Sparco Deepdish wheel and spacer *fully stripped and resprayed white *battery relocated to behind passenger seat ENGINE AND DRIVETRAIN: Engine *Ross racing pistons (2.1 litre) *Acl race bearings *Arp head, big end & crank bolts *Greddy 1.2mm headgasket *Tomei 256 poncams *tomei rockerstoppers *garrett 2871r turbo *Arc front mount *mocal oil cooler & relocator *Nismo 550cc injectors *Nismo fuel pressure regulator *Japspeed 4 branch mani *greddy elbow *greddy exhaust system *Z32 air flow metre *apexi power intake *Apexi power fc *Apexi A-VCR *High flow fuel filter *warlbro fuel pump Transmission *OS Giken supersingle clutch *Nismo Short shifter *nismo gearbox mount *Tomei 2way diff SUSPENSION: *Apexi drift coilovers *Driftworks adjustable wishbones *Tein Extra lock tie rods *Whiteline ARB front & rear *Cusco Strut brace *Cusco Castor arms *Cusco camber arms *Cusco Toe arms *Polybushed and rosejointed all round *Custom front suspension set up for extra lock SAFETY: *18 pt weld in cage *2.5 litre extinguisher *engine cut off WHEELS & TYRES: *ultralite battle 9x17 Front and back *toyo r888 235/40/17 F *Silverstone 235/45/17 R BHP: 360hp/350ft/lbs tis scary when ya write it all down and put money beside each part!!! Last edited by nigey00 : 09-07-2008 at 23:40. |
10-07-2008, 07:11
| #24 (permalink) |
| talent bypass ![]() ![]() Join Date: Jul 2004 Location: Essex
| Here goes then... Engine: Rebuilt to the following spec. CA18DET, 1853cc, DOHC JE 8:1 forged pistons Lightened/balanced bottom end Cryogenically treated rods and crank Greddy 1.2mm metal head gasket ACL Race Bearings Ported & Polished head CA16DE Inlet Cam Apexi Power FC (mapped by APT) 660cc Injectors Walbro 255lph Fuel Pump DriftWorks Flywheel Apexi Induction Kit Cold Air Box With Cold Air Feeds Garrett GT2871R Turbo French Weapon Turbo Manifold Apex Dump Pipe Z32 AFM Greddy Profec B SpecII HKS ‘S’ spec Front Mount Intercooler NGK BCR8 Spark Plugs SE-Nissan 64mm Down Pipe HKS Hiper Muffler Exhaust Electric Fans Setrab 19 row Oil Cooler Polished Intake Plenum, Pulley Cover And IC Pipes Alloy Oil Cap Blitz Radiator Cap Koyo Racing Radiator Cusco Oil Catch Tank Fuel pressure gauge. DB Power Engine Mounts Transmission KAAZ 2 way LSD Spec Stg3+ Paddle Clutch Nismo clutch pivot Nismo gearbox mount Chassis Apex Coilovers 8F/6R SE-Nissan Rose Joint Adjustable Tension Rods Tein Tie Rods, Rod Ends and Rack Spacers Cusco Front Strut Brace Modified Skyline Rear Strut Brace Powerflex/Whiteline Rear Suspension & Subframe Bushes SRB Rear Camber Arms Cusco Rear Toe Arms Whiteline Front Lower Arm Bushes Solid Steering Column Bush Poly Steering Rack Mounts 15mm spacers Front, 5mm Rear Buddy Club P1 Racing Wheels (8j ET22 Front, 9j ET27 Rear) 215/45 (F), 225/45 (R) Brakes R32 GTR Discs and Calipers Porterfield R4S Pads F&R Braided Hoses DOT 4 Race Fluid Cusco brake master cylinder stopper Modified S14 Master Cylinder Exterior Top Mix 180SX Kouki Type X Rear Spoiler Vented Headlight Cover 180SX Electric Folding Mirrors Rolled & Flared Rear Arches 180SX Side Skirts 180SX Rear Spats 180SX Front Wings Various Front Bumpers, depending what I can get hold of after smashinating them Battery Cut Off and Fire Extinguisher Pulls OMP Tow Eye Bonnet Pins Dings and Dents Lots of stickerage Interior OMP Steering Wheel Tomei Gearknob Alloy Pedals Blitz Dual Turbo Timer In Alloy Panel Autometer Guages – Oil Pressure, Oil Temperature, Water Temperature, Boost OMP RS Bucket Seat Ricco FIA 4 Point Harness 2.2Kg Plumbed in Fire Extinguisher Fabricage 6 Point Roll Cage ![]() |
