Old 09-07-2008, 22:48   #21 (permalink)
Polo
Team Green!
Polo's Avatar
Originally Posted by MJG View Post
Total cost including buying car.... £1800, less than most people's engines.
Put one more 0 on the end of that price and your still short atleast 7-8k of what mine owes me
Old 09-07-2008, 23:17   #22 (permalink)
nigey00
nigey00's Avatar
heres mine!!
LEVEL:
Pro (ireland)
CAR:
Nissan 180sx, sr20det
EXTERIOR:
*Uras S15 front bumper
*Origin S15 +30mm front fenders
*Custom fiberglass s15 bonnet
*fiberglass s15 light covers
*Ganador mirrors
*uras 180sx side skirs and rear bumper
*+50 mm rear overfenders
*Buddy club Highrise carbon spoiler
*Koki rear lights
*polycarbonate rear screen
*sprayed in ferrari red
*rear metal quaters removed under overfenders
*Front and rear archs tubbed for extra clearance
*Fully seamwelded
*Boot floor replaced
INTERIOR:
*Prodrive WRC seats x2
*D2 harnesses
*Timex guages
*Full weld in 18pt cage
*Sparco Deepdish wheel and spacer
*fully stripped and resprayed white
*battery relocated to behind passenger seat
ENGINE AND DRIVETRAIN:
Engine
*Ross racing pistons (2.1 litre)
*Acl race bearings
*Arp head, big end & crank bolts
*Greddy 1.2mm headgasket
*Tomei 256 poncams
*tomei rockerstoppers
*garrett 2871r turbo
*Arc front mount
*mocal oil cooler & relocator
*Nismo 550cc injectors
*Nismo fuel pressure regulator
*Japspeed 4 branch mani
*greddy elbow
*greddy exhaust system
*Z32 air flow metre
*apexi power intake
*Apexi power fc
*Apexi A-VCR
*High flow fuel filter
*warlbro fuel pump
Transmission
*OS Giken supersingle clutch
*Nismo Short shifter
*nismo gearbox mount
*Tomei 2way diff
SUSPENSION:
*Apexi drift coilovers
*Driftworks adjustable wishbones
*Tein Extra lock tie rods
*Whiteline ARB front & rear
*Cusco Strut brace
*Cusco Castor arms
*Cusco camber arms
*Cusco Toe arms
*Polybushed and rosejointed all round
*Custom front suspension set up for extra lock
SAFETY:
*18 pt weld in cage
*2.5 litre extinguisher
*engine cut off
WHEELS & TYRES:
*ultralite battle 9x17 Front and back
*toyo r888 235/40/17 F
*Silverstone 235/45/17 R
BHP: 360hp/350ft/lbs
tis scary when ya write it all down and put money beside each part!!!
nigey00 is offline   Reply With Quote
Old 09-07-2008, 23:26   #23 (permalink)
cookwibble
cookwibble's Avatar
lol at the huge spec lists. makes me feel better about my driving, at least i can use my low spec as an excuse
Old 10-07-2008, 07:11   #24 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
Here goes then...
Engine: Rebuilt to the following spec.
CA18DET, 1853cc, DOHC
JE 8:1 forged pistons
Lightened/balanced bottom end
Cryogenically treated rods and crank
Greddy 1.2mm metal head gasket
ACL Race Bearings
Ported & Polished head
CA16DE Inlet Cam
Apexi Power FC (mapped by APT)
660cc Injectors
Walbro 255lph Fuel Pump
DriftWorks Flywheel
Apexi Induction Kit
Cold Air Box With Cold Air Feeds
Garrett GT2871R Turbo
French Weapon Turbo Manifold
Apex Dump Pipe
Z32 AFM
Greddy Profec B SpecII
HKS ‘S’ spec Front Mount Intercooler
NGK BCR8 Spark Plugs
SE-Nissan 64mm Down Pipe
HKS Hiper Muffler Exhaust
Electric Fans
Setrab 19 row Oil Cooler
Polished Intake Plenum, Pulley Cover And IC Pipes
Alloy Oil Cap
Blitz Radiator Cap
Koyo Racing Radiator
Cusco Oil Catch Tank
Fuel pressure gauge.
DB Power Engine Mounts
Transmission
KAAZ 2 way LSD
Spec Stg3+ Paddle Clutch
Nismo clutch pivot
Nismo gearbox mount
Chassis
Apex Coilovers 8F/6R
SE-Nissan Rose Joint Adjustable Tension Rods
Tein Tie Rods, Rod Ends and Rack Spacers
Cusco Front Strut Brace
Modified Skyline Rear Strut Brace
Powerflex/Whiteline Rear Suspension & Subframe Bushes
SRB Rear Camber Arms
Cusco Rear Toe Arms
Whiteline Front Lower Arm Bushes
Solid Steering Column Bush
Poly Steering Rack Mounts
15mm spacers Front, 5mm Rear
Buddy Club P1 Racing Wheels (8j ET22 Front, 9j ET27 Rear)
215/45 (F), 225/45 (R)
Brakes
R32 GTR Discs and Calipers
Porterfield R4S Pads F&R
Braided Hoses
DOT 4 Race Fluid
Cusco brake master cylinder stopper
Modified S14 Master Cylinder
Exterior
Top Mix 180SX Kouki Type X Rear Spoiler
Vented Headlight Cover
180SX Electric Folding Mirrors
Rolled & Flared Rear Arches
180SX Side Skirts
180SX Rear Spats
180SX Front Wings
Various Front Bumpers, depending what I can get hold of after smashinating them
Battery Cut Off and Fire Extinguisher Pulls
OMP Tow Eye
Bonnet Pins
Dings and Dents
Lots of stickerage
Interior
OMP Steering Wheel
Tomei Gearknob
Alloy Pedals
Blitz Dual Turbo Timer In Alloy Panel
Autometer Guages – Oil Pressure, Oil Temperature, Water Temperature, Boost
OMP RS Bucket Seat
Ricco FIA 4 Point Harness
2.2Kg Plumbed in Fire Extinguisher
Fabricage 6 Point Roll Cage
