| | LinkBack | Thread Tools | Search this Thread | Display Modes |
04-07-2009, 15:49
| #61 (permalink) |
| Mad pointing Munky ![]() Join Date: Oct 2005
he can use my car if he wants. One small issue is it needs the new manifold put on and so far one stud removing from the block. PM me if your interested. Can use it for free providing wat ever breaks fixes and u fit the new mani for me
__________________ ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
04-07-2009, 17:36
| #62 (permalink) |
| Dori Mechanic ![]() |
Mines ready to go just mend what you bend and probably the best spec'ed one on offer. Get over befor the event and we can go do a days testing at llandow or smeatharpe. Can even put your own sponsors on for the event if you get some sorted. ![]() made 380bhp @1.6bar on a safe map boosts to 2.2 bar Engine: nismo enginge mounts new bearings and gaskets ACL pistons H beam conrods blitz spark plugs ported head Tomei 260' 8.25 lift in/ex poncams Tomei cam pulleys Tomei valve springs Jun retainers Cometic 1.9mm metal HG ARP head stud and nut kit Mocal oil cooler kit koyo ali Rad spal electric fans Inlet and exhaust: Yashio factory exhaust manifold Garrett GT3076R s14 twin chamber turbo elbow s14 3" down pipe Apex 4"thick FMIC Apex cat back exhaust ported inlet manifold with tomei throttle body Blitz dump valve Fueling: Bosch 044 fuel pump High flow billet alloy race fuel filter SARD fuel pressure regulator 1000cc fuel injectors Aeroquip alloy piping and fittings Modified fuel rail to take Aeroquip fittings Interior/safety: coberu revolution bucket seats luke 6 point harnesses fully stripped Sound deadening removed cut out weight fire extinguisher Bonnet + boot pins Cut off switch Multi point roll cage Drive train: Rb25 box conversion Uprated g/box mounts Braided clutch hose Norris designs prototype twin plate clutch 5 stud conversion front and rear Nismo 2 way LSD suspension: Whiteline anti roll bar front Whiteline anti roll bar rear Apex alignment kit Apex solid subframe bushes Apex front strut brace Apex coilovers Custom adaptions Electronics: Apexi AVCR 200 OMEX 700 management Brakes: R32 GTR calipers 280mm red dot discs braided front lines braided rear lines z32 BMC z32 rear discs z32 rear calipers tilton brake bias valve hydrolic hand brake Body: Charge speed: carbon Boot & Bonnet +50mm rear over fenders Side skirts Random make +30mm front fenders Jun front bummper Cwest carbon wing
__________________ Alex |
05-07-2009, 06:59
| #63 (permalink) |
| Await Rescue Join Date: Aug 2007
Still not found a car?? Garage D have a huuuuuge load of cars, surely one of them is workable?? Never seen so many skylines in one place lol. The little 86 looked lost parked next to the blitz skyline yesterday.
__________________ Was drift action, thats generally how you crash if your doing it properly. |
09-07-2009, 21:45
| #64 (permalink) |
| gripper Join Date: Jul 2009
hey guys im really really sorry for the stuff around but i have just been told i have swine flu unless you have been living under a rock its kind of serious and i cant even leave my house atm so cut up about this but i promise ill be over some time soon ill try working closely with dan to make it happen ffs i want to drive on the tracks i play on ps3 they look awsome hahaha again really sorry fucking pigs and there fucking flu fucking with my life reg fink |
09-07-2009, 22:34
| #70 (permalink) | |
| =The Guv'nor= ![]() Join Date: Jul 2004 Location: Fresh from Intensive Care Yo !!
| In fairness that should be standard practice for all Antipodean's !! Flu or otherwise !! Bad luck fella, its only really flu with a few pork scratchings !! J.
__________________ The future is bright.....................the future is ..........already here !!!! "Bon bon was also famous for another quality, who by the grace of countless activity, could carry unfathomable quantities in the regions(?) of his rectum. Even when given a thorough ass check." Quote:
