Old 05-07-2009, 16:44   #1 (permalink)
can any one help (turbo advise)????
hi all im new to the drifting seen but have been playing wiv me car for the last 2 years. i have a r33 gtst with all the mods that i need to be able now to add a uprated turbo. i was thinking of useing some sort of hybrid turbo but was just wondering if any one could tell me wot one i should go for. at the min i have uprated fuel pump, coolder spark plugs, split fire coil packs, apexi air filter, apexi front mount, full nismo exhaust wiv turbo elbo and de-cat, blitz boost controller, apexi power fc and a excedy stage2 paddel clutch. it made 322bhp last weekend. so i would like a turbo and a set of 555cc injectors to finish it off.
can any one help????
gobbo1986 is offline   Reply With Quote
Old 05-07-2009, 16:46   #2 (permalink)
DEYTUKURJURBS
Stavros's Avatar
What sort of power you want? As thats going to be the main thing.
__________________
Old 05-07-2009, 16:48   #3 (permalink)
i would like to run around the 400bhp mark that was why i was thinking of a hybrid instead of a hole turbo convertion kit
Old 05-07-2009, 16:56   #4 (permalink)
there is a company that we use through work that build hybrid turbos and i spoke to them and they said that they could take mine away and fit it with t34 internals and i would cope up to 450bhp. as im in the trade they said they could do one of these for £495 would this be a good idea????
Old 05-07-2009, 17:05   #5 (permalink)
DEYTUKURJURBS
Stavros's Avatar
Standard Escort Cosworth T34/T35 (depends what they decide to call it today), good for 400, spools fast as fuck, bolts straight on, winner.
Dan Chapman had one on that R33GTST he had, so he can confirm it massively badass
__________________
Old 05-07-2009, 17:07   #6 (permalink)
James N's Avatar
you using a standard 33 turbo at the moment? I think Rising Sun Performance on the Skylines Owners forum can rebuild those, and would probably be perfect for what you're after..
__________________
"I'm sick of following my dreams, I'm just gonna ask where they're goin', and hook up with them later." - Mitch Hedberg
James N is offline   Reply With Quote
Old 05-07-2009, 17:11   #7 (permalink)
yeh im on standard turbo at the min. so if i was to use either one of these it would be a good choise. would i be rite i sayin that all i would need is a set of 555cc injectors and a re-map and im good to go????
Old 05-07-2009, 17:45   #8 (permalink)
bump!!!
Old 05-07-2009, 18:18   #9 (permalink)
driftage
itsVTC's Avatar
34 minute bump?
rapage
itsVTC is offline   Reply With Quote
Old 05-07-2009, 18:21   #10 (permalink)
Originally Posted by mr.jailbait View Post
34 minute bump?
rapage
Jailbait rapage
__________________
Originally Posted by G-Man View Post
DW is such an evolved forum, it self-moderates...it's the chuck norris of the forum world...
skyvia is offline   Reply With Quote
Old 05-07-2009, 18:24   #11 (permalink)
being helpful i see!
cheers
Old 05-07-2009, 18:47   #12 (permalink)
James N's Avatar
Get on to RSP, (Rising Sun Performance) or the company you mentioned who can rebuild your turbo. With steel internals right? As thats what you want i believe, then RSP can map the standard ECU for your mods or advise you where to go from there if you're still not happy with the power..
Thats what i would recommend anyway, but there are several different turbos and tuners you could use to achieve what you're after
__________________
Search this Thread:
Advanced Search
