My clutch needs changing on my S13. I can't afford a expensive one so was wondering if there if a cheap alternative that will take some drift days. It's running stage 2 if that helps.
ACT paddle clutch is pretty good, bout £300 if I remember correctly
From £349.00 inc VAT
From £229.74 inc VAT
I was hoping for something around £200 mark. Or would I be wasting my money??
XTD stage 3 sprung clutch with 6 puck ceramic disk. ebay at us&a will be your best friend. 180usd + shipping. it's the best bang for the buck for the entry level drifting/street usage.
couple of my friends are using it on ca18 and sr20 engines. 200-350hp range and it handles just fine.
just refurbish your flywheel, degrease everything, adjust your clutch and it will hold properly.
drifting doe put alot of pressure on the clutch so try not to go cheap if possible. clutch kicks arnt friendly lol
Have you drifted on current clutch?
Just get stock for that power
stock doesn't like high rpm clutch kicks, my organic disc went out after one year of drift day abuse. ceramic disc has better initial bite so less slip means less clutch/pressure plate wear. and xtd stg3 are pretty cheap, i think you can get it shipped and taxed under 200gbp.
I dont think a stock clutch will be ok for stage 2, i've had a standard clutch for 2 years in my s14, done more clutch kicks than i can remember and it's ok but thats only on standard power. Stage 2 i'd recommend getting a better clutch, i've heard good things about ACT clutches.
From £260.32 inc VAT
From £264.64 inc VAT
Being tight assed on a clutch is a waste of time. It will just die an early death and your be having the pull the box off and forking out for a decent one that you should have bought in the first place. ACT, RPS, SPEC are all good clutches at around 300-400. I had a ACT HD organic in my s14 @ 300hp for a good 3 years then sold it to a mate when i upgraded and hes been using it for over a year now with not a wiff of trouble.
act and spec are 300+quid zone, but yeah, they are good quality clutches.
Exedy.
Spend your money on a good clutch, lot of shite about.
We have never had a single faulty Exedy, and sold lots of them
Pedal doesn't go heavy, come with a release bearing too.
My first S13 had a stock clutch in it for 2 years at stage 2. Killed it in my first round of competition though! I then fitted an RPS which was good.
Also had 2 Exedy organic clutches in 2 S14's, both of which have been great. Good feel and great bite, without being harder to drive or excessively heavy.
i like the way people can tell him a standard clutch wont handle stage 2 power when it doesent even say what engine it is.
if its a CA then i did about 20/30k @ stage 2 power on a luk replacment clutch thats daily driving with the odd streeto and doing santa pod shows every other weekend.
as always,advice is worth what you pay for it.
