Okay i bought another s13 a few months ago car drove fine on way home i did a compression test just in case so i knew what condition engine was in everything fine there. I was going stage 2 so changed the timing belt, manifold and gasket, turbo, radiator, fuel pump fitted electronic boost controller, intercooler, colder plugs, stage 2 ecu, lambda sensor. Do you think its the cas sensor thats out or could it be something else?
LinkBack URL
About LinkBacks
