Results 1 to 13 of 13
    May 2007
    ireland
    300
    SR20 engine rattle
    Ive a blacktop sr20 that has a small rattle. when you start the car from cold you cant hear it but as it warms up it starts to come through, doesnt seem to much like a bottom end but it sounds like its somewhere in the head. When you rev it to about 2k and above you cant hear it but as it comes down to idle it comes through again. its a vvt sr with about 110,000 on it, dropped the oil from it today and used engine flush, the oil seems fine nothing suspect in it. Replaced it with mobil 10 60 and it sounded a small bit worse after i started it.
    Can anyone shed light on this?
    Troll Dispatch
    Aug 2005
    teamd3.co.uk
    19,139
    Vee Vee Tee.
    Don't worry about it, common on the blacktops.
    www.teamd3.co.uk
    Facebook Drift Team D3 'Like' the Facebook page for updates throughout the season.
    the yarco
    Mar 2008
    great yarmouth
    1,637
    yeah sounds like vvt to me
    reshell under way
  4. #4
    May 2007
    ireland
    300
    Quote Originally Posted by LiGhTnInG View Post
    Vee Vee Tee.
    hopefully it is, any way of checking it for sure?
  5. #5
    Section-59
    Sep 2006
    S E London/Kent
    3,362
    Engine flush!
    Try another vvt solenoid.
  6. #6
    May 2007
    ireland
    300
    Quote Originally Posted by Jamie-PS13 View Post
    Engine flush!
    yeah i used engine flush because the car was lying up for a bit(so im told) and just wanted to flush the whole system out. can the solenoid be changed without going near the timing chain?
  7. #7
    Troll Dispatch
    Aug 2005
    teamd3.co.uk
    19,139
    Quote Originally Posted by damo View Post
    Nope. It holds the chain in place. To swap, you have to slacken the tensioner, undo the nearest cam bolts and jiggle free.
    Leave it, it doesn't hurt anything. You could put a redtop (non-vvt) one in, but it's pointless.
    EDIT: Just to add, the VVT is a little gearing device that gives your car about 40 extra horses, i THINK it retards the timing at the top end of the revs to achieve this. It uses oil pressure to work, and they commonly die because of lack of oil pressure.
    www.teamd3.co.uk
  8. #8
    Apr 2009
    Ipswich
    411
    Big ends will rattle on start up for a millysecond then will rattle 3k and above, Defo sounds like vvt rattle, why do people still use engine flush!! The stuff should be banned from every shelf, I thought the oil grade for these were 10w/50? Could be wrong though
  9. #9
    May 2007
    ireland
    300
    Once i know its the vvt and not something tryin to knock its way out of the block im not worried, as i said it doesnt sound like bottom end related so im ok there.
  10. #10
    May 2007
    ireland
    300
    Quote Originally Posted by zimm_zimmer View Post
    i used 15w50 on sr's and rb's before, i was told by a few that the 10w60 is a good alternative. I think nissan recommends 5w30
  11. #11
    Troll Dispatch
    Aug 2005
    teamd3.co.uk
    19,139
    www.teamd3.co.uk
  12. #12
    Feb 2009
    paris, france
    41
    I've got the same thing on my sr20det 97k miles, same thing after oil replacement
    Real DRIFT, RC DRIFT, DRIFT on vidéo games and good times ^^ : www.3xige.com
  13. #13
    Jan 2011
    Washington, Tyne & Wear, UK
    222
    it happens to every blacktop sr20det, dont worry about it, my mates sounded like a VW TDI lump on idle at one point and still kept running
