Results 1 to 7 of 7
    May 2010
    Galway
    225
    open engine queston
    well lads iv an rb25 there that as sitting in my engine bay with a bonnt over it for a year or more with no plugs or coilpack.havnt tryd turnin it over yet didnt want to do to much damage. is the engine salvagable? havnt got a loan of a bore scope to see how the walls are yet. just wanted to know if anyone else on here ran an engine after that lenght of time in them conditions
    May 2009
    liverpool
    886
    Id say first things first get some oil down the cylinders and let that stand for a while just incase the rings are stuck, then try turning by hand
    folowed by ign turnover then a cheap ass oil change and then try to fire it.
    If its fucked its only cost the price of cheep oil.
    Sep 2010
    551
    oil whats that going todo?
    put it in gear and rock it back and forth make sure the bottom pullys moving. if soo go for a start up. If your worried all inside is fucked spray some wd40 down the bores. thats it
    Team High Flyers
  4. #4
    #FullAttack
    Jul 2009
    Surrey UK
    4,440
    This,
    Squirt wd40 down bores and leave for a day
    Turn over by hand with socket and breaker bar on bottom pulley, or rock back and forth while in gear. If it moves, proceed...
    Fit plugs and coils, fire it up.
    SPONSORSHIP NEEDED
    Instagram: FullAttack
  5. #5
    May 2009
    liverpool
    886
    Quote Originally Posted by Maxdrift View Post
    Same shit
  6. #6
    Feb 2011
    dublin
    225
    would this be the same for a rb20 det thats had the inlet plenum off for not far off a year
  7. #7
    May 2010
    Galway
    225
    cheers lads ye i read about the wd40. i sprayed some in the other day just dont know if its goin to work out. will probly need a rebuild with a new block or bore block if its pitted. has anyone ever done this and had the motor running fine afterwards?
