Results 1 to 5 of 5
    Nov 2006
    ireland
    256
    JZX100 Chaser manual conversion info
    Anyone know what front prop and pedals I need to go with this or what will work
    I am using a R154 box so would a mk3 supra prop work or is their anything else?
    Apart from JZX90 pedals is their anything easy to get soarer,supra etc
    Cheers
    Aug 2010
    869
    mk3 front half prop + a custom made rear half should be no problem
    be careful with the shifter tho, chaser needs the remote shifter
    not sure about pedals but i think soarer/mk3 supra should fit with some modification
    best is to get a complete manual kit off a jzx that will guarantee fit with out hassles
    Nov 2006
    ireland
    256
    Quote Originally Posted by davisyip View Post
    I have the remote shifter and every other part to do the job
    If I could get my hands on JZX stuff 2nd hand it would be ideal but its not that easy
  4. #4
    #FullAttack
    Jul 2009
    Surrey UK
    4,414
    Your chaser prop will fit into the box, not sure if it's the right length but I know the output shaft is same for auto & manual.
    SPONSORSHIP NEEDED - 2013 BDC
    Instagram: FullAttack
  5. #5
    Dec 2008
    1,782
    You'll need a JZX prop front section. I think, but don't quote me, a 66mm extension should do it.
    The only pedals which are straight direct fit are JZX100. The 90 ones sit a bit low for some reason and need a little nick taking out of them, bending up and welding...if you're into that sort of thing.
    However, the carrier is the same between models and the actual pedal arm isn't too dear from Toyota. Soarer and Supra don't fit for toffee and again, are slightly different between models but still fit without modification.
    We have complete JZX90 conversions in stock minus boxes as we're out of those and can supply you the arm direct from Toyota.
    Give us a call, email or PM and we can sort you out.
    Many thanks,
    PPUK.
