Results 1 to 5 of 5
    Nov 2006
    ulverston, cumbria
    343
    Ca18 idle, or lack of
    Wondering if anybodys had this problem before.
    Car was fine until taken to a drift day, developed a missfire there, fixed that. Brought it home and left it, now it will not idle at all?
    It starts fine, will run if you keep some throttle on, but instantly cuts out as soon as you let off?
    Moslty standard, big front mount, stock boost, 3'' exhaust.
    Any ideas would be great thanks
    In moderation
    Jul 2004
    Derby
    16,723
    Has the small hose come off the idle control valve? It goes to the intercooler pipework near the throttle body.
    Nov 2007
    1,748
    Read ECU codes
    Compression Test.
    boost or vac leak
  4. #4
    May 2012
    34
    sounds like ICV issue to me
  5. #5
    Mar 2009
    Hat-rock
    512
    God I hate ca's sounds exactly the same as mine I just threw my toys out of the pram and started building a New one I had lying about, be sure to update when you find the problem
