Morning Gentlemen Ok, now i have had my r33 gtst for a few months, i have found a few parts that i am unsure off 1 x apexi safc, the original style with 5 or 6 little knobs on, they all seem to be set at the 12 oclock position http://wctsmultiservizi.com/products/apexi-safc-super-air-flow-converter-s-afc-8 i suppose the main question is, can i tune the car with this instead of getting a new ecu. 1 x hks actuator thingy, not 100% sure what this is or does or what else its connected to, however from what i can see it has a small pipe coming from the part and then goes into the side of the intake manifold. any help would be greatly appreciated
You can tune a car with a SAFC, but only mild stuff, slightly bigger injectors, etc. And HKS actuator- You mean wastegate actuator or? Post a pic.
That looks like a weird little fella. Where to the pipes and wires go?? Maybe it's the boost pressure sensor for an electronic boost gauge or something??
