JZ boffins - can you tell me if i've got this right? I'm trying to work out all the gear for what needs to go behind my engine... Engine: JZX100 1JZ VVTI Gearbox: Mk4 Supra W58 Bellhousing: JZ to w58 Flywheel: Mk4 Supra 2JZ NA Clutch: Mk4 Supra 2JZ NA Clutch Slave: Mk4 2JZ NA Hybrid Toyota/BMW prop, BMW rear end. And before anyone says it, yes I know the W58 "will only hold up to around 450whp". I don't think that's a concern (yet)...
I wouldn't be so ambitious about 450whp. Maybe 400whp max. 350whp to be safe. Bellhousing from the same MK4 NA 2JZGE Supra.
So in actual fact, i'm massively over-complicating this all. Everything I need is Mk4 NA Supra stuff. Thanks for the reply.
