Looking for a little help I have done a 1jz conversion sorry not into a drift car so kept the auto, car is up and running but i have no overdrive switch wired up yet. i can see 2 pins on the ecu for over drive one says it goes to the switch one goes to cruise control ecu ? i dont have the cruise control any idea were the other wire from the overdrive switch would go to ?? any help appreciated
Not into auto boxes, but on a wild guess I´d say it need grouning, like most things, like the diagnosics, and the kickdown as far as I remeber...
Just look at the wiring diagrams that are all over the Internet.. Most components use ground as trigger, so will probably require a power input and the switch switches to ground to activate.. But check!
