Just wondering what ideas ppl have got to clean this engine block up iv used brake cleaner and a toothbrush , paint brush etc jet wash but cant get it any cleaner want it to look reallly clean an new
You mean the bare silver aluminium? All that's visible is just discoloured/corroded alloy, so you'd need a wire brush or similar abrasive to get it better. It's 'clean' as it is, the white bits are corrosion. You'll struggle to do that properly to anything but a bare block removed from the bay.
Yer the silver aluminium i no i probs wont make it perfect but id like the try get it as good as i can
Stiff nylon brush - wire wheels and wire brushes are a cunt because they are so aggressive on the aluminium. The brake cleaner is what causes the white powdery stuff. In all honesty, thats a pretty clean SR. Most are black on the front.
As above, plus you'll only make it look "as new" with a bit of paint. It looks cleaner than any SR I've seen (I'm sure that's what this thread is really about anyway), so well done - go and slide it.
Dont get carrried away son it not ur engine cos its in my car lol iv ordered some alubright gna give that a try with a small wire brush to work it in
Paint. You won't do any better than what you already have. I don't understand the fixation, it's clean.
The fixation is yes its clean but..... All the white shit and dull ness on it i want it to look as good as i can physically get it witch i dont think is a bad thing its shearly looking after my car
The issue is with the dremel is, yes - it's very high speed but the bits don't last that long and will leave you with polished spots. You can get brass wire wheels instead of steel, maybe try that on a drill
