Sr20det S14 oil pressure issue's
Thread in 'Technical Questions' started by nkyS14, May 13, 2016.
  1. nkyS14
    nkyS14 Member
    I have recently finished my engine, bottom end running forged internals, oem crank shaft, acl bearings, acl orbit oil pump and using 15 50 motul oil. I took the readings from a prosport oil pressure gauge. Cold start reads 80-90psi and warm idle reads 20-25. Some times it drops to 10 psi on idle. That is what's bodering me.. :/ can any one give me some suggestions on the problem.
    Sent from my iPhone using Tapatalk
  2. nkyS14
    nkyS14 Member
    Bump pls
  3. clonehunter
    clonehunter Member
    Seriously impossible to say without hearing/seeing/feeling/licking etc.
    Disasemble again and look for errors....but first of all, check your gauge and try another one
  4. nkyS14
    nkyS14 Member
    That's what i am trying not to do hehe
  5. clonehunter
    clonehunter Member
    Your best bet is to check your gauge and disasemble everything like oilcooler, thermostat, relocationkit etc etc.
    so back to stock (if there is something)
    If its not that or simply your gauge reading wrong...well you have a problem :D
  6. Ads899
    Ads899 Member
    If you find out what this is pls post it I have just had my oil pressure warning light come on first time ever car was extremely hot plenty of oil in it so unsure made me really worry
  7. nkyS14
    nkyS14 Member
    I will try clone. It only happens after i get on it... Idle drops down to 10psi from 20ish
  8. Vlad_SX
    Vlad_SX Member
    Raise the Idle RPM....i had the same issue with all the SR's i've built...or get the RNN11 oil pump. My daily SR idles hot with 15psi pressure, and the old one, with the RNN11 pump ran 20psi hot. AND OIL COOLER!
  9. nkyS14
    nkyS14 Member
    Got an external oil cooler and am running an acl orbit oil pump. Will try raising idle, its 850rpm stock right?
  10. BenRice
    BenRice Well-Known Member
    Try a different brand of oil as well
  11. nkyS14
    nkyS14 Member
    Any oil you can suggest? Over here we suffer from heat, summer is as hot as 30-40 degrees.
  12. BenRice
    Anything name brand. Keep the numbers the same though.
    The only other thing other than a faulty oil pump could be that your oil pick up is dented and restricting flow. The heavier weight oil could be masking this when cold.
    But best to try a different gauge & sender first
