Outside chance someone might have these dimensions, or know where I might find them without dropping the prop off my car? · Length of Propshaft, from oil seal to the flange · Length of the transmission sleeve from Universal Joint centre to the end of transmission sleeve · The number of splines on the gearbox stub · The outer diameter of the transmission sleeve · Flange face diameter · The flange PCD (Diameter between the centre of the bolt holes across the face of the flange) · The universal joint measurement, including the cap diameter and the universal joint span. Cheers
