Old 08-12-2006, 00:49   #1 (permalink)
scrutineer
scrutineer's Avatar
firewalls
i have had a few questions about firewalls
for the front, the standard bulkhead between the engine and the passenger compartment is good enough..... if all holes in it are filled in -
make sure wires through it are in grommets
if you remove anything that leaves a hole inthe bulkhead it needs to be filled with ali,fibreglass, fireproof mastic etc
The easiest way to check is to have a strong light one side of the bulkhead and look at it from the othe side.... if you can see any light then the hole needs filling
for the boot - if the boot is empty - no fuel tanks, swirl pots, fuel pumps,nitrous then a firewall is not needed. If the boot has anything like that in it then you need a firewall between the boot and the passenger compartment
as with any of the regs if your not sure ask here,pm me or email me
Old 07-02-2007, 20:34   #2 (permalink)
e30 of Death
I will probably be having the filler neck of my fuel tank, and the fuel pumps, as well as the battery in the boot. This is more concerned with eurodrift but I want to comply to your specs if possible.
Am I alright to just rivet in a sheet of aluminium over front of rear archs, and back to under the rear window? Making sure no holes apart from for battery cable (with grommet)? This should be as good a firewall as the car's floor ever was!
Old 07-02-2007, 20:56   #3 (permalink)
sideways.taff
-NightWalkers-
sideways.taff's Avatar
Seal it too Mike
sideways.taff is online now   Reply With Quote
Old 07-02-2007, 21:16   #4 (permalink)
e30 of Death
What with Bryn? Silicone or something? Or something specific?
Old 07-02-2007, 21:28   #5 (permalink)
sideways.taff
-NightWalkers-
I cant remember what stuff we used to use at university to seal the firewalls on the forumla student race car. I'm sure someone will know! I need to know and I can't for the life of me remember what it was called.
Old 07-02-2007, 21:35   #6 (permalink)
sideways.taff
-NightWalkers-
Right, just been doing some digging. I think (emphasise on think) that it was polyurethene sealant and that's the same sort of stuff you'd have as seam sealer irc.
Old 07-02-2007, 21:44   #7 (permalink)
e30 of Death
OK, why was it a specific sort? Heat resistance? To be fair I'm sure nobody would know what sealant I used as long as it did the job haha. The plate is going to be pretty flush with everything anyway.
Old 07-02-2007, 21:48   #8 (permalink)
gaz_moose
.MTM.
look in the msa blue book young sir.do everything to fia regs.
Old 07-02-2007, 21:53   #9 (permalink)
e30 of Death
I don't have a blue book. I will read yours
Old 07-02-2007, 22:00   #10 (permalink)
gaz_moose
.MTM.
it says you have to use fire proof spastic sealant all of ze way round.
Old 07-02-2007, 23:49   #11 (permalink)
scrutineer
scrutineer's Avatar
screwfix may be your friend: product number 20830 firestop 400 intumescent acrylic sealer £4.59 a tube.
or product number 20981 is a fire rated expanding foam
there are other similar products available but ordinary mastic can burn very well
or fibreglass seals it well
Old 09-02-2007, 13:13   #12 (permalink)
e30 of Death
Thanks guys, cheers scrutineer dude
Old 09-02-2007, 21:20   #13 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
surprised your suggesting fibreglass as a means of sealing a bulkhead as its very flammable,
or should i say the resins are that bond the fibres
Old 09-02-2007, 21:29   #14 (permalink)
rallyman1978
hachiroku
rallyman1978's Avatar
I've used fireproof expanding foam before on a mk2 escort
Good results but gets everywhere and is a fucker to get off clothing and hands
rallyman1978 is offline   Reply With Quote
Old 10-02-2007, 00:07   #15 (permalink)
scrutineer
scrutineer's Avatar
interesting point - i was under the impression that when cured, it did not burn easily-certainly not as easily lit as many of the cured mastics and better than an open hole.
marc
Old 10-02-2007, 01:33   #16 (permalink)
Alex B
Alex B's Avatar
Send a message via MSN to Alex B
marc
Doesn't catch easily, (as in you couldn't light it with a match/lighteer etc), but burns very well when it does go and gets extremely hot.
Alex B
Alex B is offline   Reply With Quote
Old 12-02-2007, 13:18   #17 (permalink)
e30 of Death
Fibreglass it is then, burn myself then SUE!! Hahaha only joking.
I'll try and find one of the screwfix things you first recommended marc
Old 13-02-2007, 00:05   #18 (permalink)
scrutineer
scrutineer's Avatar
Hmmmmm .............its so nice when this years troublemaker identifies himself before the first event
at least now i know who to persecute........
new rule 17-8: the scrutineer will pick one car each event and have it stripped down to a bare shell to make sure the paint is of the required thickness.If the scrutineer desires this can be the same car every event - maybe each day!
at the risk of taking this too seriously the idea is that if you have a fire or fuel leak etc the flames/fuel will not easily/quickly get to the driver.
It is assumed that the driver will notice the sheets of fire coming out of the boot and stop ..... exiting the car rapidly and leaving a brown mist of adrenaline.
It is not anticipated that the driver finishes the run if this happens.
Therefore a product that will not light easily but is a very effective seal can be appropriate for firewall use .........
Old 13-02-2007, 10:43   #19 (permalink)
e30 of Death
Hahaha, yeah I was pulling your leg. I cannot see myself entering any events anyway but the regulations are a good guide, just like a lot of people really
Also, just checking, is it OK to have a fuel tank/pump in the boot, with a battery also? They would both be secured and at least 12" away from eachother, and firewalled off as above, but is that OK or would the battery need to be in a box or something?
