31-03-2007, 21:26
| #22 (permalink) |
| BDC ![]() Join Date: Feb 2005 Location: Germany....Now!
| its listed as a motorsport battery. Designed to cope with raised Temperatures and Harsh Environments The Hawker PowerSafe SBS 40 Battery has a proven long service life and up to two year shelf life. It's compact size and high energy density make the PowerSafe SBS 40 a popular 12 volt power supply in competition vehicles. PowerSafe SBS 40 has a low ventilation requirement and wide operating temperature range. The case is impact resistant and flame retardant to UL94 V-O. The leak resistant dual terminal design allows the PowerSafe SBS 40 to be mounted in any orientation except inverted. General Specifications Nominal Voltage: 12 volt Nominal Capacity: 10 hr rate to 1.8Vpc @ 20°C = 38Ah Length: 9.8" (250mm) Width: 3.8" (97mm) Height: 8.1" (206mm) Typical Weight: 28 lbs (12.7 kg) Short Circuit Current: 2184 A Internal Resistance: 5.6 Mohm Terminals: M6 M Last edited by DriftLexus : 31-03-2007 at 21:30. |
01-04-2007, 10:03
| #23 (permalink) |
| spl dori master Join Date: Aug 2006 Location: sussex
| from the description i would not be sure - it would need to have a gel inside rather than liquid acid .... that one sounds like its more leak resistant than normal but still liquid ( unless the maker says different)- the problem is with the chance of getting acid slopping around in an accident.... acid burns as well as a bent car would really piss you off. Unless you find out for sure that its not liquid i would say its best to put it into a box - a cheap plastic one would be fine. Last edited by scrutineer : 01-04-2007 at 10:07. |
01-04-2007, 19:39
| #24 (permalink) |
| yeah maybe so. says in the specifications that the battery is sealed and the acid is absorbed into a seperator material its definatly sealed i can see that much, there are no caps as a test i left it on its side for 3 days ![]() i have no intention of mounting it in the passenger compartment.....but just wanted to explore all possibilitys if it helps others Last edited by DriftLexus : 01-04-2007 at 19:44. |
02-04-2007, 10:41
| #25 (permalink) | |
| S13 RB25DET ![]() Join Date: Dec 2004 Location: Friesland
![]() I've been doing robotwars in the past, and the scrutineering is pretty strict there, especially on batteries, because the robot's fly all over the place. The hawker SBS was approved there ![]() | |
