26-03-2007, 22:16
| #3 (permalink) | |
| spl dori master Join Date: Aug 2006 Location: sussex
sadly scrutineering is my spare time interest - my employer has\the nerve to expect me to work during the day assuming the battery is the normal "wet" type of battery : 4-17. Batteries must be securely mounted and all connections in a serviceable and clean condition. Negative leads should be braided or have yellow identifying marking. Batteries housed in the driver compartment must be securely mounted in a sealed and insulated box this really tells the story - it must be securely mounted in a box- aluminium isn't the best material as its conductive and so the battery would need more insulation. the basic needs are to secure the battery and to make sure any spilt acid isn't slopping round inside the car | |
26-03-2007, 23:06
| #4 (permalink) | |
| Doricomotion ![]() | Quote:
thankyou. explains it perfectly. I wasn't being impatient, merely bumping it to the top of a very active forum. I appreciate your response. | |
26-03-2007, 23:24
| #5 (permalink) | |
| Mr Sir | Quote:
![]() Dont forget to cover your battery terminals, gaffer tape is the usual material of choice for the job, in the case of an accident we dont want some conducting material pressing down on your battery and causing a potential source of fire. Rob | |
26-03-2007, 23:35
| #6 (permalink) | |
![]() I was considering a marine plastic battery box. but didn't think it would pass regs as they were cheap. not much of the stuff that'll pass regs is cheap ![]() i'm fitting the battery to the inside of the car, and will cover it with a plastic battery box. Not to worry, it'll be secured usinng proper battery clamps ![]() Was thinking about doing it in the passenger footwell. | |
26-03-2007, 23:38
| #7 (permalink) | |
fair enough. .... I've been in London all day without the laptop so couldn't get on the net (normally check mail several times a day) | |
27-03-2007, 06:55
| #8 (permalink) | |
| talent bypass ![]() ![]() Join Date: Jul 2004 Location: Essex
Youre right, it might have got lost amongst the other active thread in the EDC forum.![]() ![]() | |
27-03-2007, 19:42
| #12 (permalink) | |
27-03-2007, 21:25
| #13 (permalink) | |
| Hachi Roku is the way | Quote:
its in this thread eurodrift car prep, Novice | |
