03-04-2007, 01:17
| #2 (permalink) |
| spl dori master ![]() Join Date: Nov 2006
| Some entrants are not receving emails it appears so here goes: Timetable 08.00 Venue Opens 08.30 Driver Sign On 09.30 Driver Briefing Drivers go into two groups Odd and Even numbers Two sections of circuit will be used, A and B 10.00 Practice Starts with Odds on A circuit and Evens on B circuit 10.30 Groups change circuit 11.00 Groups change circuit 11.30 Groups change circuit 12.00 Lunch & Briefing 12.45 Licensing Odds A and B 14.15 Licensing Evens A and B 15.45 Driver Briefing Those moving forward to Twin Drifting section of Licensing announced 16.00 Twin Drift Starts 16.30 Twin Drift Finishes 16.45 Driver Briefing and License Announcement 17.00 Venue Closes Timings are subject to change and are quoted as a maximum so the event may finish earlier. You will practice and be judged on two seperate circuits, if you get past this you will then have to Twin Drift for the final decision(s) to be made. It is not guaranteed that every driver will get through to the Twinning. The Licensing day has a serious side but is also there to be enjoyed .Make sure you are on time as if you have not signed on and are not in the briefing then you will not run. More information will be made available on the day for those entering. The entrance to Drift Central is as follows: 1. Head for the paddock entrance at Doningotn Park Circuit. 2. Just before you pull up to the security barrier you will notice a small road on your left leading upto a pair of metal gates. 3. Go through the gates, bear round to your right and follow directions from there. 4. The gates will be locked from 09.15. Looking forward to seeing you guys on Friday. Regards, |
