Old 04-04-2007, 20:54   #61 (permalink)
Phil
Admin
Phil's Avatar
We finished the oil pump swap on the RB25DET, and managed to get the car to alignment by about 4pm. Turned out nearly every single bolt on the drivers side of the rear subframe/suspension was loose, and the main drive shaft nut was loose, this all equated to over a cm of movement on the back wheels .. That's what you get when you try to align the car on the tarmac at Teeside with the wrong size spanners, and 8 hours sleep in 48 hours .. Got that all sorted, and the car now feels nice and tight now ..
Only problem is.. I've developed a really really bad misfire on boost. I think I've completely knackered the previously cracked and repaired inlet manifold... Foooooooook Now I need to find an RB25DET inlet manifold by tomorrow morning, as I'm only 95% sure that that's the problem.
Phil is online now   Reply With Quote
Old 04-04-2007, 21:24   #62 (permalink)
Matt_S
SELLIN' UP!!!
Matt_S's Avatar
Well, I got it aligned
Battery cut off now works properly!
Fire Ext all in and tidy, just need to attach the little metal stop thingies and cut a cable to length if I have time
So its now all down to my Bro making me the pull bracket, other wsie I may well me asking for donations to 1000 rolls of gaffer tape to stick em out the corner of the bonnet
Matt_S is offline   Reply With Quote
Old 04-04-2007, 21:54   #63 (permalink)
NOS anyone?!
NOS anyone?!'s Avatar
do you have to have racing boots and gloves for EDC?
NOS anyone?! is offline   Reply With Quote
Old 04-04-2007, 22:12   #64 (permalink)
scrutineer
scrutineer's Avatar
Yes
that part of the regs is pretty much the same as last years D1GB:
4-19. Drivers must wear approved fire protective apparel and safety device/s with a minimum equipment level of: Crash helmet (open face helmets are allowed although we recommend full face), racing overalls, racing boots, gloves and balaclava. Optional equipment recommendation: Fire proof undergarments and HANS device
marc
Old 04-04-2007, 22:23   #65 (permalink)
jackadoodledo
jackadoodledo's Avatar
re-shell car between now and friday midday
jackadoodledo is offline   Reply With Quote
Old 04-04-2007, 22:41   #66 (permalink)
sammysideways
re-shell?? wtf?? si do you think you can make it, i can come up early friday and leave late for extra hands if you think you will dude...??
Old 04-04-2007, 22:47   #67 (permalink)
Matt_S
SELLIN' UP!!!
Matt_S's Avatar
Yes. Another £110 spent last week
Old 04-04-2007, 23:08   #68 (permalink)
Brunosr13
Brunosr13's Avatar
not really re-shell isn't? this mean not pratice friday?
good luck mate, hope see you there on saturday
Brunosr13 is offline   Reply With Quote
Old 04-04-2007, 23:08   #69 (permalink)
jackadoodledo
text me tommorow when you sober up to let me know if your serious
if you are then see you friday , but aiming to get to the pratice on friday afternoon
Old 04-04-2007, 23:11   #70 (permalink)
sammysideways
ill be there dude...9 in morning ok for you??
Old 04-04-2007, 23:11   #71 (permalink)
jackadoodledo
by using another shell....then yeah it is
mainly moving engine/box etc over
exhaust and brakes
all wiring
fitting front end parts
i'm at work all day tommorrow, so this has all gotta happen overnight on thurs/fri morning
Old 04-04-2007, 23:12   #72 (permalink)
jackadoodledo
i'll put the kettle on for then
Old 04-04-2007, 23:16   #73 (permalink)
sammysideways
we at dme?? you know im a complete spastic but even if i just do the simple stuff it will free you up to do the real man labour!!
Old 04-04-2007, 23:16   #74 (permalink)
Brunosr13
Brunosr13's Avatar
exhaust and brakes
all wiring
Shame you just know about this now, after months
Old 04-04-2007, 23:29   #75 (permalink)
jackadoodledo
okay, you can be tea boy
Old 05-04-2007, 00:05   #76 (permalink)
peter barber123
and i thought i was cutting it fine
best of luck si
peter barber123 is offline   Reply With Quote
Old 05-04-2007, 01:32   #77 (permalink)
J.c
Send a message via MSN to J.c
good luck guys !! might make it down aint to sure yet
J.c is offline   Reply With Quote
Old 05-04-2007, 02:04   #78 (permalink)
Moffatt
4.6 V8 Mustang, BMW!
Moffatt's Avatar
Send a message via MSN to Moffatt
It will be done! starting in 7 hours pulling the engine and box apart, finially got steve's car done and now simons! mines at the back and i wont be there
But we will do our best for the 6th week straight 2 am finish!!!!!!!!!!!!!!!!!!!
Sammy, milky with 2 sugars every 30 mins please
Moffatt is offline   Reply With Quote
Old 05-04-2007, 06:59   #79 (permalink)
Mitch
GRDriftGarage
Mitch's Avatar
A bit late in the day to be putting it into another car, Simon. Mister Smith appears to have his work cut out with his 180 too. Good luck with them both fellas, and hopefully we'll see you all tomorrow.
I'm going to wash and pack the car today, do a couple of little bits and maybe make a tow eye in case my one doesn't rock up.
Old 05-04-2007, 09:35   #80 (permalink)
kieran_e1
In need of practice
well all bar graphics , mine was finished last night!!
kieran_e1 is offline   Reply With Quote
