Closed Thread
Old 01-05-2007, 10:30   #1 (permalink)
scrutineer
scrutineer's Avatar
D1 big hit ..... the aftermath
a few drivers that remain nameless need to do some safety work and/or get new helmets before silverstone - all were noted for follow up
please dont forget!
from memory:
helmets - must be to EDC regs - NO motorcross
engine cut out switches/ battery isolators
plumbed extinguishers
if these items are not fully up to spec the car will not be going out to play..... even on the friday!
mr unpopular this decision was made last week but today seemed a good day to post it
scrutineer is offline
Old 31-05-2007, 22:00   #2 (permalink)
Bladerider
=The Guv'nor=
Bladerider's Avatar
Just a note,
If you buy him a pack of Werthers original and tickle his tummy he goes away after a couple of minutes !!!
Bladerider is offline
Old 31-05-2007, 23:35   #3 (permalink)
scrutineer
scrutineer's Avatar
Originally Posted by Bladerider
Just a note,
bacon butties work better
did some one mention rollcage paddding?
Old 31-05-2007, 23:56   #4 (permalink)
Bladerider
=The Guv'nor=
Bladerider's Avatar
Oh FFS !!!!!!!!
Old 01-06-2007, 11:06   #5 (permalink)
narcotic
narcotic's Avatar
Send a message via MSN to narcotic
can i ask why motorcross helmets are excluded?
just thinking out load here.... but bailing out of a jump say 15-20 foot above the ground would give a harder knock/blow to the head than say kncoking yourself against some rollcage padding strapped into your car with your lovelly bucket seat and harness holding you inplace.
narcotic is offline
Old 01-06-2007, 22:28   #6 (permalink)
scrutineer
scrutineer's Avatar
this is a point that has been raised in DW numerous times and the answer stays the same no matter how many times its asked if you want a more detailed explanation try a search but basically the tests different, the construction is different a motorsport helmet is built to take repeated impacts instead ofwhat maybe a single impact
and the acu gold test is pretty much a useless bit of paper (IMHO) due to its alleged abuse in the past by manufacturers of cheap (crap) helmets
we do not put these rules in place to make you spend money - they are there for the drivers safety
thread closed
Closed Thread
