Go Back   Drifting forum - Driftworks > F o r - S a l e / W a n t e d > Japaneseusedcars.com
Old 05-11-2007, 15:11   #21 (permalink)
maximilion
BIG PIMPIN
maximilion's Avatar
Send a message via MSN to maximilion
ah right my mistake. looking back at it, it is pretty obvious lol, gah i saw it ages ago
maximilion is offline   Reply With Quote
Old 05-11-2007, 22:38   #22 (permalink)
BillyFIVE
no disassemble
BillyFIVE's Avatar
Old 05-11-2007, 22:49   #23 (permalink)
NikDev
Drifts a Swede
NikDev's Avatar
Nice, inloove with the camo cef and the rex`es are sexy too!
Anyone from UK joining them too D1 All-stars?
NikDev is offline   Reply With Quote
Old 07-11-2007, 12:53   #24 (permalink)
maximilion
BIG PIMPIN
maximilion's Avatar
hes got a na rotary in that hasnt he? but the big one, forgoten the name all of a sudden 13b is it called? sounds nice tho
Old 07-11-2007, 12:58   #25 (permalink)
cefiro_drifta
mad pointing munkey
cefiro_drifta's Avatar
i could be wrong but i think its a quad rotary
Old 07-11-2007, 13:20   #26 (permalink)
maximilion
BIG PIMPIN
maximilion's Avatar
yea cant remeber what its called but yea its got more rotors, and it sounds nuts, which that car does.
Originally Posted by cefiro_drifta View Post
iirc it wasnt mike in that vid it was Justin Rood and he was just doin a rolling burn out
thats the vid i was takin bout? it is mad mike.
Old 07-11-2007, 13:33   #27 (permalink)
Bon Bon
What Pizza?
Bon Bon's Avatar
Howcome he doesn't make any smoke? Needs to learn the way of the man foot.
Old 07-11-2007, 13:35   #28 (permalink)
maximilion
BIG PIMPIN
maximilion's Avatar
in this one he gives it a little manfoot in the middle, but just listen to that sound!
and in my defence, he does a rollin burn out, then trys to launch and it dosent grip, dosent look like hes usin the brakes.
Old 07-11-2007, 19:53   #29 (permalink)
NikDev
Drifts a Swede
NikDev's Avatar
How do you think people are doing burn out`s? they are using the brakes! And he uses them there
Old 07-11-2007, 20:02   #30 (permalink)
cefiro_drifta
mad pointing munkey
he def uses the brakes .. the guy has 19" wheels on the back so he would get grip and wouldnt stay at a low speed all the way ... he probably has a line lock
Old 08-11-2007, 00:37   #31 (permalink)
Autospecs
JDM Car Export
Autospecs's Avatar
Here's the full spec on Mikes car
FURSTY SPECS
96 MAZDA FD3 RX7
POWER PLANT: 20b short crank 3rotor, Kiwi-RE Peripheral Port, lightened balanced hi comp RX8 rotors, hi-rev mod, Custom end & centre plates, hand built chromolly crankshaft, 3 window bearings, hand fabricated intake runners, MOTEC 55mm throttle bodies, Primary & secondary staged injectors, MOTEC fuel rails, WALBRO lift pump, Kiwi-RE surge tank, BOSCH 044 EFI pump, Malpassi regulator, BOSCH 616 coils, Custom MSD leads, NGK plugs, hand fabricated tuned length headers, 3” stainless exhaust to custom ‘Humpy’ pipe, Alloy radiator, factory twin oil coolers, Kiwi-RE oil breather, stainless heat shroud, DAVIS CRAIG electric water pump, MICROTECH LTX-12, all factory wiring removed.
DRIVE LINE: Factory series 6 five speed, Kiwi-RE custom flywheel, Solid centre twin plate clutch, MAZDASPEED 4:3 crown wheel on Custom full spool Locker.
SUSPENSION & CHASSIS: TEIN Super Drift equipped with EDFC, Custom steering arms, Custom tierods, Mod fire wall & chassis for steering clearance, Cut rear quarters for wheel clearance, D2 Air Jack setup
BRAKES: Factory brakes with EBC pads all ABS removed, B&M launch control kit
WHEELS: WORK eqip 18-12 rear, 18-11 front
TYRES: GOODYEAR eagle F1 265/35/18’s
EXTERIOR: BN-Sports BLISTER widebody, I.T.S Fridge white with matt black half split, Custom CRE8GRAFX digital camo.
INTERIOR: Carbon SPARCO seats, SPARCO wheel, SPARCO knob, GREEDY gauges, TEIN EDFC, 6 point rollcage, RCI harnesses, Custom alloy dash & door skins.
Autospecs is offline   Reply With Quote
Old 08-11-2007, 02:19   #32 (permalink)
maximilion
BIG PIMPIN
maximilion's Avatar
cool nice one mate! cheers for the full spec! do u happen to kno what his gear shifting gadget thingy is, its like a big round thing with the gear stick on top, saw it in a video, i think it ables you to sequencial shift, but with a normal gear box. as at one point its off the car and he shows it and when he pulls it the bottom bit moves around in a usual H pattern, but he only shifts it back and forward, anyone kno what it is? if its what i think it is, its the coolest thing ever and i want it! lol
Old 09-11-2007, 14:03   #33 (permalink)
-WJ-
S13 RB25DET
-WJ-'s Avatar
ikeya sequential shifter
-WJ- is online now   Reply With Quote
Old 09-11-2007, 16:04   #34 (permalink)
maximilion
BIG PIMPIN
maximilion's Avatar
it looks different to that one, but yea its the same thing! wow i didnt kno u could have a sequencial shift without a trillion pound sequencial gearbox! thats coooool, any idea how much they cost?
gay.....the ikeya costs £1,400 not including shipping....
Old 17-11-2007, 18:36   #35 (permalink)
Beezy
Pimp slider!
Beezy's Avatar
I want that Spec!!!!!!!
Old 28-11-2007, 08:49   #36 (permalink)
Autospecs
JDM Car Export
Autospecs's Avatar
JR Vaughn Gitten won the 2007 All Stars see below for how it panned out.
Old 28-11-2007, 12:14   #37 (permalink)
shaiz
shaiz's Avatar
Does anyone know who makes the bonnet used on Adam Richards WSR Cefiro?
shaiz is offline   Reply With Quote
Old 28-11-2007, 12:34   #38 (permalink)
cefiro_drifta
mad pointing munkey
u got a pic shaiz ?
Old 28-11-2007, 12:36   #39 (permalink)
shaiz
shaiz's Avatar
There's one on the first page of this thread but it's not great. I'll see if I can find anything better tonight though mate.
Old 28-11-2007, 12:41   #40 (permalink)
cefiro_drifta
mad pointing munkey
it looks alot liek the one from aeromasters.co.jp
aeromaster
