17-06-2009, 13:11
| doughnutter |
Hi everyone! JP here from Ireland, I've been a member on here for a while but haven't done much posting as you might have gathered. I currently drive the Sapphire Blue S14a you see in my sig & have her working right finally shoving out a good 436bhp & 512Nm of torque or 415bhp & 544Nm depending on whose dyno you prefer! ![]() I haven't drifted her before as she's my daily driver but since I'm looking for a new home for her, if she sells as one she may end up being a weapon of a drift-car for someone! ![]() Current spec is as follows: Tomei Poncams GReddy Rocker Stoppers Brian Crower Valve Springs Brian Crower +1mm Oversize Inlet & Exhaust Valves Head ported by Martin Treacy @ Westward Precision Engineering Tomei 1.2mm Metal Head Gasket ARP Head Bolts ARP Main Bolts ARP Eagle Conrod Bolts Eagle Forged Conrods CP 86.5mm Forged Pistons (Block rebored by Martin Treacy @ Westward Precision Engineering) ACL Main Bearings ACL Thrust Bearings ACL Racing Rod Bearings ATI Dampened Crank Pulley GReddy Alloy Pulley Set Power Enterprise Kevlar Belts APEXi Air Filter & Top-hat Custom inlet stainless steel hard-pipe by Calicagesracing GReddy Short-Port Inlet Plenum with Pulsar N15 SR16VE 70mm Throttlebody Powertune mild steel ceramic-coated exhaust manifold Tomei Expreme 3” Turbo Elbow 3” downpipe-back exhaust with Blitz NUR Spec-R back-box, de-cat silencer & custom silenced mid-pipe by Calicagesracing Garrett GT2871R turbo with 0.86 A/R, 2.75” inlet and 0.7bar adjustable actuator Aeroquip braided turbo feeds (water and oil) Samco Hosing Bailley Blow-off Valve NGK Iridium Spark Plugs – IK24 SARD 280L/hour in-tank Fuel Pump 2.8L Custom Stainless Steel Fuel Surge Tank by Poggy Bosch 044 External Fuel Pump Goodyear 8mm Fuel Lines GReddy Top-Fed Fuel Rail SARD 1000cc injectors FJO Racing Low Impedance Injector Driver SARD Type-RJ Fuel Pressure Regulator 800bhp Front-mounted Intercooler Custom intercooler stainless steel hard-piping by Calicagesracing MOCAL 19-row oil cooler with thermostatically-controlled sandwich-plate and 10mm braided oil lines 800bhp Aluminium race radiator Nismo 1.3bar radiator cap APEXi Power FC D-Jetro & FC Commander Mapped for E85 Bioethanol (104RON) by Stiv Blitz Dual-SBC Spec-R Dual Solenoid Boost controller APEXi Turbo Timer with Battery Voltage, A/F Ratio & 02 Meters TEIN Super Street Coil-over Suspension with pillow-ball top-mounts and EDFC (in car) controller TEIN Rose-Jointed Front Adjustable Castor Arms TEIN Adjustable Front Top-Mounts TEIN Tie-rods & tie-rod ends Apex Bushed Rear Adjustable Camber Arms Cusco strut braces (front and rear) Whiteline Adjustable Anti-Roll Bars (front and rear) Nismo engine mounts Nismo gearbox mount Mazworks short-shifter Mazworks Z32 Gearbox Conversion Plate & cross-member Custom aluminium single-piece prop-shaft OS Giken Twin-Plate Clutch Standard S14a Automatic LSD (3.9 final drive) Powerflex Main Subframe polybushes NRG Suspension polybush Kit NRG Diff Polybushes 350Z Gold Brembo Calipers (front & rear) 350Z Brembo disks (front & rear) Brembo pads (front) & DS2500 pads (rear) Braided brake lines (front & rear) Z32 Brake Master Cylinder Cusco Brake Master Cylinder Stopper Interior: Standard sleeper-spec! ![]() Genuine Nissan chrome sill plates (200SX logo) Cusco oil catch tank Custom "Rockstar" Radiator Overflow Tank Exterior: 350Z 6-spoke 18" x 8" Alloy Wheels (front & rear) So ehhh, yeah... hi!
__________________ You definitely CAN... with THIS Nissan! ![]() |
18-06-2009, 23:52
| #6 (permalink) | |
| doughnutter | I have a feeling I know you... does the name Martin & Mitchelstown ring a bell? ![]() Quote:
Thanks - it's a fun combination!
__________________ You definitely CAN... with THIS Nissan! ![]() | |
13-07-2009, 04:03
| #16 (permalink) |
| gripper Join Date: Mar 2009
Mel and myself both have a part in the SWRC forum, which you should have already joined by now ![]() That really is a seriously spec'd 14 you have there lad. Great to see such work going into them..
__________________ SWRC - Home to the Ulster Drift Championship and Irish Drag Championship - www.sideways-racing.com |
