Results 1 to 6 of 6
    May 2012
    1.5 dci clio daily driver problem
    just need a bit of help i was driving home and the car just died the engine light started flashing and then didnt come back on. the car started a few times idled and then died again the batterys fine and theres nothing obvious the enging temp was fine and i wasnt speeding or accelerating hard. when i tried to start it this morning it wont start but does turn over and the engine light flashes then goes off but only when turning the car over not when the ignitions on. an help would be aprieciated as im completly stumped
    Jul 2007
    Bognor, Nr. Chichester, West Sussex
    936
    Get on diagnostics, if the light is flashing it would indicate a level 2 fault so it could be shutting itself off. I've done loads of injectors and pumps on these. Also a batch of these engines had problems with the turbo variable vain arm seizing in the turbo.
    Sent from my Desire HD using Tapatalk 2
    Jul 2010
    Margate/Kent
    704
    Just take it to a garage no one can diagnose something like this over the interweb
  4. #4
    Diesel Skidder
    Oct 2011
    ★Tongue punching your Mums fart-box★
    1,066
    I see what the problem is.
    Its a clio
  5. #5
    Diesel Skidder
    Oct 2011
    1,066
    And your only 2 posts on a drifting forum are asking questions about your clio
  6. #6
    Nov 2009
    Vientiane, Lao.
    1,142
    Get it plugged straight in and see what fault codes. At the moment the only suggestions I could give would be guessing! If you prime it with the hand primer will it start?
