Results 1 to 2 of 2
    Banned
    Jun 2008
    Slough
    1,026
    rx7 fc3s turbo 2's stage 1 power gains?
    any one have any idea on power gains on stage 1 conversion on a 13b turbo 2 fc3s? and a list of things needing to to make it stage one
    i take it
    walbro fuel pump
    fmic
    induction kit
    exhaust
    chip
    cheers
    thanks
    in advance
    May 2008
    Beaconsfield, Bucks
    1,793
    no idea what stage one is, but.....
    ECU chip, full through exhuast, Intake and a boost controller will get you to 0.9 bar boost which depending on your engine could be 280-300 BHP which the turbo will maxed out at. An intercooler would be advised as the stock intercooler starts becoming inefficient around 0.9 bar. Depending on your exhuast you may also be required to port your wastegate.
    The standard fuel system will cope with this but it will be maxing out. rewiring the fuel pump is recommended as well as replacing all fuel filters and making sure the injectors are in good nick. For added safety I'd uprate the pump and the rad
