Results 1 to 8 of 8
    'The Vision'
    Sep 2007
    1,711
    1.5 way Vs. 2 way LSD
    Right, I'm having to bite the bullet and start saving for a diff soon. I can only go for so long with a borrowed one!
    I know the technical differences between 1.5 & 2 ways, so all I want to know is your thoughts/experiences/advantages/disadvantages with both 1.5 & 2 way. I've done my research into it, I just want to know actual experiences between the two now. Driver feel etc
    Obviously I plan to be doing some drifting in the car, but would enjoy doing some normal track days in it as well. The car is an 86 with a basically stock 4age 16v (no uprated cams etc)
    Let's hear it...
    Mar 2005
    2,129
    I've tried both in 14s grip and drift and I prefer 2ways always but the 1.5 way gave less understeer on turn in in the wet.
    S14 Silvia
    Aug 2008
    Cheshire
    4,159
    Wow, you're good.
    I can't tell the difference!
    Drifting Experiences & Practice Days
  4. From the Driftworks Shop
  5. #4
    Apr 2010
    Wolverhampton
    80
    My two way in my rx7 is very loud (my only slight dislike), my 1.5 in my 200 sx is very quiet, if your doing more road than track/drift I would go with 1.5
    Regards Ade
  6. #5
    Aug 2008
    Cheshire
    4,159
    Quote Originally Posted by AdeR32 View Post
    Regards Ade
    I don't reckon that's because it's 1.5 or 2 way, more than likely the individual diff or the car (soundproofing etc). The difference is when you shut off the power, the 1.5 doesn't lock as aggressively as a 2 way. As I said I'd struggle to tell the difference unless they were in the same car. But both drive better than a welded diff.
  7. #6
    Oct 2009
    956
    Just get a 2 way and be happy
    I run a TRD 2 way in my AE86 and its hardly noticable under normal driving and even spirtited driving , its only when agrevated or prevoked that you can tell its got a 2 way in it ohhhh and the constant low whine but then i have a full stripped interior
  8. #7
    May 2008
    Beaconsfield, Bucks
    1,443
    Quote Originally Posted by Karan View Post
    was this turn in when coming off the throttle?
  9. #8
    'The Vision'
    Sep 2007
    1,711
    Great stuff. Thanks for the info.
    I think all that was in the back of my mind was that the 2 way would be a little 'harsh' as opposed to the 1.5 way. But I think I'll stick with my original plan of a 2 way then!
    Cheers, James
