Results 1 to 14 of 14
    Nov 2009
    Warwickshire
    142
    CA18DET Stage 1,2,3
    Evening all - Again.
    time for my next daft question.
    been looking at uprating the engine etc (currently a seemingly strong but standard ca18 with 86k on the clock)
    i have a fmic, decat stainless exhaust system and an air filter to fit. i'm sure the usual modifying rule of thumb applies here, ignore manufacturer claims - i'll be lucky to see 10bhp gain... but back to the point.
    i've been looking at stage 1/2/3 "spec's" and there doesnt really seem to be straight forward spec. i'm aiming for a stage 3 CA with around 300-330bhp mark for a giggle.
    some people suggest a T3 turbo, others an s14 t28 and others an s15 t28r or a gt2871... the list goes on. whats an easily affordable way of achieving this power and someone please tell me what blower is best suited.
    i'm hoping a straight forward t28 will bolt right up and offer the power (as its cheap) but who knows? and will the stock sr manni fot the ca head etc and what injectors/chip or ecu or mapping etc etc etc
    right, i think thats my headache explained well enough (or badly enough) cheers for any help all!
    Nov 2009
    Warwickshire
    142
    also have an EVC5 about the house somewhere which may help? i duno
    Oct 2009
    Edenbridge Kent.
    234
  4. #4
    Nov 2009
    Warwickshire
    142
    i suspect its more complexed than fitting an exhaust, filter, fmic and ebay chip to see a gain of 100-130bhp??
  5. #5
    Jan 2006
    936
    edited
  6. #6
    LOOSE!
    Apr 2010
    Welwyn
    1,687
    i don't get all this stage bollocks. It seems pretty meaningless "buy my chip" shite.
    PS13 K's x LOOSE
    UP ALL NIGHT GOT DEMONS TO FIGHT
  7. #7
    Sep 2007
    Gloucester
    933
    My (hopefully) stage 3 spec is:
    300hp+
    Fmic
    Air filter
    Z32 afm
    444cc injectors
    Stainless straight through exhaust no cat
    Stainless exhaust manifold
    T28 turbo with oil drain relocated to face down (the sr20 oil return is different to the ca)
    Stainless turbo pipe with 1 hole filed to fit t28.
    Boost controller
    High capacity fuel pump
    Chipped ecu
    And from what ive read with the t28 turned up too about 0.8-1 bar should get me around 300 hp!
    Stage 2 i think consists of:
    around 250hp
    Fmic
    Air filter
    Boost controller.
    Chipped ecu.
    Stage 1 also not 100% sure is:
    around 200hp
    Fmic
    Air filter
    Chipped ecu.
    Basically the stage's off ecu chip are changes in fuelling and air as in the stage one chip removes the factory limiter and adds a bit more air and fuel were as the stage 3 will add lots more air and fuel thus the need for the afm larger turbo with increased boost high capacity pump and larger injectors. you know you cant just bolt on a big bastard turbo an turn the boost up with no fuel to compensate that leads to det and your engine going pop.
    im not takeing anybody for stupid here just trying to be as informative as i can.
    There are a few more uprated mods ie big rad ,fly wheel,clutch but these arnt need technically for stage 3.
    hope that helps dude.
  8. #8
    Aug 2008
    Cheshire
    4,188
    Quote Originally Posted by Ollie View Post
    Me too.
    Drifting Experiences & Practice Days
  9. #9
    Nov 2009
    Warwickshire
    142
    cheers Lokisy!! big help! and as for the rest of you stage haters... i also agree but its useful as a bench mark - no i know what turdbo etc i need etc.
    cheers!
  10. #10
    Sep 2007
    Gloucester
    933
    No worries dude glad to be of help and the t28 and t28r are basically the same bar the fact the t28 is journal bearing and the t28r is roller bearing. Its more reliable at higher boost but you pay the extra for it.
  11. #11
    Nov 2009
    Warwickshire
    142
    awesome - can buy 2 and ahalf t28's for the price of a t28r so i'd rather do that!
    "Build it, race it, break it - repeat"
  12. #12
    Nov 2007
    1,161
    Quote Originally Posted by Project_Drift View Post
    NO NO NO
    they are a completly different drive! the t28r will spool up so much quicker than the t28 that it makes it a completly different car to drive, after having a t28r i would never go back to a standard t28. i'm sure anyone with actual experiance will say the same.
  13. #13
    Sep 2007
    Gloucester
    933
    slightly different turbine angles and spool speed yea but a big price difference! and he wanted to know a good turbo for getting 300hp for a chuckle so a t28 should suit fine.
  14. #14
    Jul 2011
    Guildford
    116
    my 47000 miles CA has walbro fuel pump, FMIC, scorpian full system standard T25 running just over standard boost and stage 2 chip in the ECU and it pulled just over 220 bh, currently fitted a T28 r and about 14 psi of boost and pulls like a train but still spools abit later than what i first thought
