Old 12-12-2006, 20:17   #1 (permalink)
YashioFactory
YashioFactory's Avatar
how to use the Bee*R
Before thread gets hi-jacked, were all aware that this device isnt good for your car, but so a lot of things arnt good for us that are cool
anyway just bought one of these & gonna fit it on the weekend.
theres rev1 rev2 & the gain switch (from left to right)
am i right in thinking that if i set rev 1 to 5000rpm, this is when the bangs etc will occur, but wil the car rev out normally to 7000rpm also or no?
rev 2 - m guessing all the launch control setting does is select the revs for the car to stay in - simply keeps the revs in certain zone so you dont just wheel spin, but dont know why the handbrake has to be on for it?
can someone shed some more light on this for me please or tell me if i am way off..
cheers
YashioFactory is offline   Reply With Quote
Old 12-12-2006, 20:23   #2 (permalink)
Dex
kut!
Dex's Avatar
Send a message via MSN to Dex
the handbrake is the "switch" for the launch control
Old 12-12-2006, 21:11   #3 (permalink)
Dubstar
dubstar.uk.com
Dubstar's Avatar
Send a message via MSN to Dubstar
rev 1 sets the rev limit - if its set to 5000 then thats the limit. ignition is cut at that point and 5000 becomes your max limit, and the ignition comes on and off as it bounces of that limit causing the bangs
rev 2 is connected to the handbrake - so it will only work as a kinda launch control. (more useful for having it at a low rev when parked and using it to shoot flames / bang)
the yellow gain is to set the bang... the lower the number you get a b b b b b b bang the higher the number you get a BANG
(rev1 and rev2 basically do the same thing just one works with the handbrake)
Dubstar is online now   Reply With Quote
Old 12-12-2006, 21:22   #4 (permalink)
YashioFactory
nice 1.
think i understand fully. just hope its simple enough to install now
Old 12-12-2006, 21:57   #5 (permalink)
James
Lights out!
James's Avatar
if you click 'home' at the top of the page, then 'resources' there's a fitting and useage guide for the Bee-R limiter that Maz translated
Old 13-12-2006, 18:19   #6 (permalink)
NIcad7
DRIFT*DIVISION
NIcad7's Avatar
Now that Yoshio Factories problem has been sorted can i hijack the thread
and ask what is the problem with these rev limiters then?? (apart from it sounding like someone has slipped a grenade down your exhaust!)
Old 13-12-2006, 19:00   #7 (permalink)
Firestorm
Send a message via ICQ to Firestorm
all those little "explosions" damage your turbo, as well as your catalytic converter. metal cats are a little more durable but most stock ceramic cats break pretty fast if you have a rev-limiter installed...
Firestorm is online now   Reply With Quote
Old 13-12-2006, 19:06   #8 (permalink)
daim
Send a message via MSN to daim
http://www.driftworks.com/catalog/pr...tuning-exhaust
daim is offline   Reply With Quote
Old 13-12-2006, 20:37   #9 (permalink)
YashioFactory
they are not good for your rocker arm apparently, but you can get an upgraded one or something for 50 quid ?
CA18DET doesnt have rocker arm tho
but you must think - there are lots of things that are not good for your car - dipping the clutch, wheel spinns etc
Old 13-12-2006, 22:07   #10 (permalink)
NIcad7
DRIFT*DIVISION
NIcad7's Avatar
Quality, as soon as my steel internal'd turbos go on ill be getting one off these babies,
Always wanted to know what made the Bee R324R go KABOOM round silverstone, sounded intence!
Cheers lads
Old 13-12-2006, 22:16   #11 (permalink)
TaxiDori
BEER CLINCH
Mine was good fun on my silvia but i was too scared to put it on the Skyline.
TaxiDori is offline   Reply With Quote
Old 13-12-2006, 22:21   #12 (permalink)
Dubstar
dubstar.uk.com
Dubstar's Avatar
i had mine in the skyline, but only used it on rare occasions.
got some serious explosions, and was always useful when someone was tailgaiting you !
Old 13-12-2006, 22:22   #13 (permalink)
Ali
Ali's Avatar
Was also mentioned that its hard to keep your exhaust system in one piece with a BeeR fitted
Ali is offline   Reply With Quote
Old 14-12-2006, 00:10   #14 (permalink)
little_ant
what damage would one of these cause on my FD rx7?
little_ant is offline   Reply With Quote
Old 14-12-2006, 09:22   #15 (permalink)
James
Lights out!
James's Avatar
the basic problem with the Bee-Rs is that they seem to work by intercepting your timing signal to the ECU and introducing a random element to it, problem being this means you have unburnt fuel and a spark that randomly fires, so you end up with all the explosion power that should be used for pushing the pistons down occuring in the manifolds, in the combustion chamber at the wrong time, in the turbo etc etc etc
The end result seems to be snapped rocker arms, knackered turbos and exhaust systems that seem to blow themselves apart
They're good fun and they kind of work ok if you use them conservatively, but if you abuse them and use them to make mental loud banging noises (and let's face it, who can resist a little tweak of that knob) they can start to cause problems
Old 14-12-2006, 14:07   #16 (permalink)
Nelo
Resident Alco
Nelo's Avatar
Send a message via MSN to Nelo
And exhaust and turbo gaskets too! Don't use one on an SR20 unless you have the rocker arm stoppers fitted. RB/CA are OK since there's no arms.
Nelo is offline   Reply With Quote
Old 14-12-2006, 14:23   #17 (permalink)
Shyne
Shyne's Avatar
little_antwhat damage would one of these cause on my FD rx7?
As James says, they trick the ECU's timing signal, not too chronic for a boinger, but with a rotary if you can't control the signal for the spark and its delayed then you can have it catch the Apex seal and badda-bing theres your rebuild and no compression on 2 of the 6 faces. Remember, theres a twin spark and a waste spark so if its randomly altering "A signal" then its a high increase on timing hitting the seal. Not sure if anyone runs one, but worth checking the forums mate
Shyne is offline   Reply With Quote
Old 14-12-2006, 22:24   #18 (permalink)
Minishonk
Send a message via MSN to Minishonk
do these work on na engines?
Minishonk is offline   Reply With Quote
Old 15-12-2006, 09:28   #19 (permalink)
James
Lights out!
James's Avatar
they should do, yes.
The other thing to remember about a Bee-R limiter is that these work on top of what you already have in place, so if your standard ECU will only let the engine rev to 7250rpm, the Bee-R will only do anything if you set it below this point.
Old 15-12-2006, 09:29   #20 (permalink)
-WJ-
S13 RB25DET
-WJ-'s Avatar
yes...
-WJ- is offline   Reply With Quote
