Results 1 to 9 of 9
    Aug 2006
    114
    t25 on ca18et
    been out tonight on "private" roads, when i come on full boost theres like this high pitched grinding noise, also the boost is intermittant!
    im currently running a std t2 at the mo, which has been running at a bar for a number of months, im thinking this is causing the problem..
    when im accellerating and i lift the throttle so im at about 0.8 - 0.9 bar it dissapears??
    car pulls really well when the boost decides it wants to come in!
    fi its gone no big deal, as iv got a mint t25 also a t28, but will i have to upgrade anything else like the injectors or the ecu map to run the t25?
    also has anyone had any experience with fitting the t28 to a ca18et?
    will check the tubby tomorrow in work!
    TRAMP DRIFT At its finest!
    .MTM.
    Jun 2005
    round a bend
    7,407
    check the turbo for play in the shaft sounds like the impeller is touching the outer casing.i dont know about et engines and there upgrades sorry maybe ask on s12oc
    Banned
    Jan 2007
    LONDON TOWN
    2,433
    my mates turbo made this noise untill it was too late the blades dug into the compressor housing his car drove like an n/a after no turbo or boost really expencive repair if you damaged ur blades
  4. #4
    Aug 2006
    114
    Quote Originally Posted by skyludeboy
    iv checked this morning it seems to be the turbo bearings! #
    theres shite loads of play and the compressor blades are shot to bits!
    the housing has seen better days too!
    im not suprised as i know the turbo cant handle the amount of boost i was asking of it but seeing as i have a spare 25 thought id see how long it would last!
    done well, three practise days and sheds load of abuse on the street (6 months!)
    roll on the t25!!
  5. #5
    Aug 2006
    114
    anyone know if the t25 is a direct fitment?
    any mods needed to be made to the oil/water feeds?
    will hopefully fitting it within the next week or 2!
  6. #6
    Banned
    Jan 2007
    LONDON TOWN
    2,433
    all t serious manifolds are same fitment you can fit either t25 or t28 turbos
  7. #7
    In Safe Hands
    Jun 2005
    Woodstock, Oxfordshire
    8,453
    I don't know first hand, but your probably going to have to rotate the core to get it to all line up. But a T25 flange is a T25 flange - should bolt straight on.
    Way too old for signatures
  8. #8
    Aug 2006
    114
    Quote Originally Posted by Mr Bizzle
    done a bit of research on the s12oc, thinks it can bolt straight on!
    will be getting it sorted hopefully this weekend or next!!
  9. #9
    Dec 2006
    nr high wycombe
    861
    u will need the s13 t25 elbow ,rotate the compressor housing and u will also need a oil feed made up aparently , u mite need to cut a lug off the gearbox aswell to clear the t25 elbow
