01-01-2008, 19:36
| #21 (permalink) |
| ______________ ![]() Join Date: Aug 2004
| Has the exhaust note got louder ? blowing loads of black smoke? I had a problem once were my actuator arm fell off and was not allowing it to boost at all ! but if you gunned it hard it started to come onto about .5 bar. clarkey. |
01-01-2008, 21:22
| #24 (permalink) |
| Poor ![]() Join Date: Feb 2006 Location: In the sky
| First thought was boost leak tbh. But couldn't find anything. Haven't tested the actuator as i'm not sure how to do it. Do you think the ECU is in limp mode. If so any ideas on how to reset it. Failing that - Ed sounds like you need to get your boost pipes checked on a tester. Could be a pin hole somewhere. |
01-01-2008, 22:10
| #25 (permalink) |
| if the ecu was in limp mode, it would rev over 4k, just test you ecu out of your car in his. could be an AFM problem, does he have a HKS filter by any chance ? And boost leaks can really be anywere and hide really well ! |
04-01-2008, 12:59
| #26 (permalink) | |
| RWD Carless Join Date: Nov 2005 Location: Milton Keynes
![]() My skyline is slower after 70 than my Omega which goes alway to 153mph on long enough stright stretch of PRIVATE motorway![]() Last edited by EDnovaStarlet : 05-01-2008 at 13:57. | |
05-01-2008, 14:02
| #28 (permalink) | |
) made no diffrence at all . Running a biltz filter.How do I test ecu out of my car ?Bunnys is a reprogramable ECU will it lose it's setting's if taken out and put on mine? Or is the software writen in so if battery disconected wont harm programming? ![]() Running at a lose end with this car, thinking of selling it to some1 who knows wot there doing! ![]() ![]() ![]() ![]() ![]() | |
16-06-2008, 22:33
| #29 (permalink) | |
| spl dori master Join Date: Nov 2006 Location: Grantham/Lincoln
so just gotta put a neat engine to ecu loop and all should be fine ![]() also had to tighten up a few boost leaks ![]() Last edited by Cypher : 22-06-2008 at 21:40. | |
22-06-2008, 21:41
| #30 (permalink) |
| or not.... did the same a he said...hitting 5k and misfires galore....im out of ideas...other than changing the ignitian amp pack.... tried everyhting in the thread..even put a new different ecu on to check that... |
22-06-2008, 22:10
| #33 (permalink) |
| the ignition amp is what CHUNK said when we picked up some parts a while back! I cleaned up the earths on it to no avail! If that does sort it go done the wasted spark kit! Anyone else ever had this problem??????? Last edited by EDnovaStarlet : 22-06-2008 at 22:13. |
23-06-2008, 21:32
| #38 (permalink) |
| gripper Join Date: Mar 2006
| Sounds like 1 of these IMO: AFM buggered or the power supply to... Timing way off Low fuel pressure... either thru bad pump/blocked fuel filter or a vac hose leak or similar causing FPR to not function properly Turbo's wastegate actuator vac pipe either split or not connected... would generate too much boost as a result ECU power supply faulty, but this would result in 'Safe mode' cut off at 2K rpm's... so probably not that in this case Faulty Lambda sensor or power failure to... runs in 'open loop' as a result and retards timing etc Idle switch is sticking on... thinks it's always idling, and pulls timing etc Weak spark maybe, or poor power supply to PTU... obvious bad spark and spluttering etc results That's all the poss's I can come up with at this point... you need to start eliminating things and try to narrow it down mate, as there's too many things possibly causing it to just assume it's spark related IMO. ![]() Last edited by Nize : 23-06-2008 at 22:04. |
25-06-2008, 19:18
| #40 (permalink) |
| Not the smallest list of things to work thru mate, but some things only take a few minutes to check. ![]() Im actually thinking now that a Vacuum hose leak is quite possible... and this would cause it to run lean, and could create the same problems as your having. Also the lambda sensor can get 'tired' with age, and can cause poor fuelling... any electrical tests you wanted to try, just PM me and I can write you out instructions of what to test and where etc... you just need a multimeter for most. ![]() Hope you find the problem mate. ![]() Nize. |
