12-03-2008, 19:47
| doughnutter Join Date: Nov 2006 Location: Norway
| 1jz vs 2jz Hi guys! Next winter I'm doing a JZ swap in my r32. But I don't know if I should choose the 1JZ or the 2JZ. concidering the weight the engine will be pushed back atleast 30cm (like the DW s15) to maintain a respectable weight distrubution. Will everybody post their pro's and con's for both engines? Cheers Nico ![]() |
12-03-2008, 20:43
| #6 (permalink) |
| Dorifto! Join Date: Jul 2007 Location: Tyndrum-up in Scotchland
| its the engine that is most commonly found in the supra and a few other japan imports eg jz90 chasers etc etc(i think so anyway but ill prob be corrected) read this:Toyota JZ engine - Wikipedia, the free encyclopedia |
12-03-2008, 20:53
| #9 (permalink) | |
![]() http://www.driftworks.com/forum/drif...4-rebuild.html http://www.driftworks.com/forum/drif...-page-5-a.html | |
12-03-2008, 23:50
| #13 (permalink) | |
| Pimms O'clock ![]() | Quote:
A bit of tweakage & single tubby conversion they are both awesome engines, my 1JZ makes 1 bar at 2.5k rpm with a big turbo & is as responsive as hell, probably more so than you actually want to get the power down. However they are cheap for a reason, they don't blow up as a rule, but you Neeeesaan boys won't like that at as you'll lose the I've blown my engine X times kudos & its considered a bit gay to not blow at 2 or 3 engines per seasons. So move on now leave the JZ for my projects & they'll never work in S bodies the wieght distrubution is all wrong & its gay just ![]() Last edited by cptsideways : 12-03-2008 at 23:54. | |
13-03-2008, 16:32
| #19 (permalink) | |
| dorifto kingu! | Quote:
So I'd hardly call that gutless. Even with my previous stock twins, at 1 bar, it did 330 bhp and 550 Nm. | |
13-03-2008, 16:55
| #20 (permalink) |
| dorifto kingu! ![]() Join Date: Apr 2005
| gutless??? no. a standard 1jz will pretty much destroy any RB engine for torque and tunability. the reason they are cheap is cause there is no demand, they break rarely. manual gearbox will be your only headache, but thats not going to be too bad. great engine, your only problem will be that your neeeesahn will fall apart from the torques or just rust away to nothing before you can get the engine in |
