22-05-2005, 15:17
| #61 (permalink) | |
| -NIGHTSPIRT FAMILY- ![]() ![]() Join Date: Jul 2004 Location: in a world of hate
also dude, your supossed to bash the arch out of the way of the wheel, not bash the arch into the way of it ![]() | |
22-05-2005, 17:10
| #65 (permalink) |
| should i change the thread title to "learning mitto to spell thread" seriously, i just type, i dont go over and check it. people chill. like i said, its not a spelling forum, its a drift one ![]() |
22-05-2005, 17:29
| #67 (permalink) | |
| R32 GTR-S ![]() | not that low, i was running 255/35/18 on a 18*9.5 et15 with a mad arch flare and it hit it, the back can go lower now i have hammered the inner arch out the way. Quote:
25-05-2005, 14:33
| #68 (permalink) |
| Bringing this back up top the top... Rear camber... (totally ignoring doing it to clear arches) Increasing or decreasing it, effects? zero (ie dead flat, providing the suspension movement dont make it change) seems almost ideal, but im no drift pro, not yet anyhow ![]() |
25-05-2005, 14:41
| #69 (permalink) |
| dangerous brotherhood Join Date: Jul 2004 Location: soy de croydon
| Dead flat would be ideal IF there was absolutely no roll on the rear. however there always will be some roll and ideally you want the outside tyre flat when the car rolls to give as much control while sideways. Between 1.5 and 2 degrees negative seems ideal on my s14. It also decreases contact patch when in a straight line which means less grip. The other reason that negative camber is ideal is because unless u have adjustable rear toe arms when u lower it the toe/camber goes fubared. For instance when i first got the tracking gauges on the car i had 1 degree negative camber and 10mm toe out. Had to settle on 1.75 degrees negative with 5mm toe out. Although i really like it that way, especially as im running pretty low power. Last edited by Tom : 25-05-2005 at 14:45. |
18-05-2006, 08:27
| #73 (permalink) | |
| spl dori master ![]() | Quote:
Someone please make it sticky. Thank you. | |
05-10-2008, 23:19
| #74 (permalink) | |
| tail slider Join Date: Jun 2008 Location: Walsall
would this be ideal for a daily driver too? or just track slag, im running standard wheels, so tyres are 215/55/15 Last edited by mashed : 05-10-2008 at 23:29. | |
