Old 02-05-2008, 22:40   #21 (permalink)
xborninthefightx
xborninthefightx's Avatar
Well they sell spray cans, but dont know if its the same as the other stuff
Old 02-05-2008, 22:43   #22 (permalink)
affy
F.Y.E
affy's Avatar
Send a message via MSN to affy
wait so is it possible to use hammerite paint through a spraygun and compressor?????????? if this is correct i know what type of paint to stock up lol
affy is offline   Reply With Quote
Old 02-05-2008, 22:47   #23 (permalink)
Goddaz
Yeah affy i was thinking the same.. haha
Goddaz is offline   Reply With Quote
Old 02-05-2008, 23:13   #24 (permalink)
Polo
Team Green!
Polo's Avatar
Yea if you thin it down with thinners
Old 03-05-2008, 00:37   #25 (permalink)
retrodan
celebs in car
retrodan's Avatar
meh, flated it off after removing minemal rust, then used black rattle cans, in the cold outside, turned out pretty shiney, and fairly tuf wearing!! cost me about 15sheets in cans, about 2/3 i think!!
Old 03-05-2008, 02:22   #26 (permalink)
smokey
smokey's Avatar
Send a message via MSN to smokey
i just used a rattlecan on the subframe, but used a brush on the diff housing cause it's cast. was just a lot easier to use a brush for that.
smokey is offline   Reply With Quote
Old 03-05-2008, 09:37   #27 (permalink)
Dan H
Dan H's Avatar
When I did mine, I used a wire brush in a drill to get the rust and loose paint off, gave it a wipe with thinners, then sprayed it with a tin of underseal stuff.
I wasn't fussed about it being shiny.
Dan H is offline   Reply With Quote
Old 03-05-2008, 10:11   #28 (permalink)
Jord
GRD Drift Club
Jord's Avatar
Ive been told brushing Hammerite on to get a good covered and THEN going over with a can of the same colour Hammerite sprayed on will get rid of the crappy brushed finish.
Old 03-05-2008, 14:36   #29 (permalink)
affy
F.Y.E
affy's Avatar
cheers dude im going to take a crack at my mates subframe on tuesday using hammerite through a gravity feed air gun and comperssor, found a nice mint green colour ill post some pics up when its done , has any one tried painting an entire car with these or is it not recomended
Old 07-05-2008, 10:25   #30 (permalink)
Jord
GRD Drift Club
Jord's Avatar
Anyone got any suggestions for a REALLY strong degreaser?
Got some stuff I used before painting surfaces in the house but its not shifting this thick oil/grease on this subframe.
Old 07-05-2008, 10:30   #31 (permalink)
Karan
i use gunk and its pretty good, you have to wait around for it to really dig in though and you still have to brush heavy grease etc
Karan is offline   Reply With Quote
Old 07-05-2008, 18:36   #32 (permalink)
Dan H
Dan H's Avatar
Use a scraper to get the worst of it off, then cellulose thinners
Old 07-05-2008, 18:57   #33 (permalink)
sammysideways
me and a mate brought what we thought was gunk engine cleaner...usen on his engine bay then realised it was gunk driveway cleaner or sumat similar!lol. worked fricking well though...really strong dont get near your eyes or cuts etc
Old 07-05-2008, 19:55   #34 (permalink)
JONXLR8
Technohead
JONXLR8's Avatar
I wire brushed mine with a drill, applied Kurust in a few hard to reach places, two coats of Red Oxide and two coats of Hammerite. Doesn't look pretty but it's a lot better than before and it's well protected now.
JONXLR8 is offline   Reply With Quote
Old 07-05-2008, 20:39   #35 (permalink)
kiruji
Loving E30...
kiruji's Avatar
Bit late now, but I used POR15 on the subframe and inner wings. That stuff is hardcore.
kiruji is offline   Reply With Quote
Old 09-05-2008, 14:54   #36 (permalink)
affy
F.Y.E
affy's Avatar
after the advice i was given (hammerite can be sprayed with an gravity feed gun, i done a bit of experiments with it trying to get a candy effect i sprayed a silver hammerite mixed with thinners and then sprayed light green over it mixed the same way and finally cheated using 2k laqure. finish was amazing so i got carried away and did more bits the same way rocker cover, strut brace
pics
Old 09-05-2008, 17:38   #37 (permalink)
Goddaz
oooh that is nice!!
