Old 05-05-2008, 21:54   #1 (permalink)
turbo-tastic
E36 issues
New car, new problems
I've done about 400miles in my 328 now, and it has a slight judder when braking. If I just press the pedal enough to slow down a bit on the motorway its quite harsh, but if I stand on the brakes to stop quickly I dont notice it at all
I'm thinking its warped discs, but my experience with BM's is usually some bush is feckered. Any ideas which one??
And while I'm under the car (or probably while Mark is under the car ) what suspension is worth fitting? I want to drop it and lose the body roll, but having never bought aftermarket stuff for anything non JDM I'm a bit lost on what brands are good etc
turbo-tastic is offline   Reply With Quote
Old 05-05-2008, 21:57   #2 (permalink)
ren_juanjo
buttercakes!!
ren_juanjo's Avatar
Send a message via MSN to ren_juanjo
i had this before on my 328. was the front wishbone rear bushes. exactly same symptoms.
suspension that is good - eibach, bilstein, gaz
ren_juanjo is offline   Reply With Quote
Old 05-05-2008, 22:08   #3 (permalink)
neil a walker
neil a walker's Avatar
careful with the rear springs being too low coz you end up with quite a bit of neg camber on the back if they are, and tyre wear on the insides goes through the roof
had eibach sportline springs on mine with koni@s (45mm drop front) 30mm rear) and was too much, can get corrector bolts and camber arms but eibach ones are silly money for what they are
Trailing arm bushes and rear damper bushes go quite quick too. (rear knocking)
neil a walker is offline   Reply With Quote
Old 05-05-2008, 22:16   #4 (permalink)
turbo-tastic
Nice one, cheers
Worth upgrading to poly bushes or not? Its not gonna be a stripped out, coilover'd dedicated drift slag as its my daily hack.
Niel, roughly how much are we looking at for the camber arms etc?
Old 05-05-2008, 22:19   #5 (permalink)
ren_juanjo
buttercakes!!
ren_juanjo's Avatar
yeah dont lower it too much at the back, about 40mm tops so the standard rear camber bolts will be able to dial the camber out. i'm down about 60mm and running 3mm of rear neg camber, its rubbish.
its worth polybushing both the rear bush of the front wishbones, and the rear trailing arm bushes. all other ones should be fine to leave standard for now. it wont make it too crashy.
Old 05-05-2008, 22:30   #6 (permalink)
neil a walker
yeah, definatly! the rear trailing arm ones kinda press in the arms by squeezing then together and have a alloy insert that sits on the carrier faces, its concaved rubber bush ie.... )-( so it has sum sideways movement for ride comfort, but tend to split from the alloy, powerflex ones are like 2 top hats with a steel insert and the poly sits nearly flush with the carrier face. So theres much less if any sideways play. They're all pretty soft and squidgy and tend to split from the inserts so would be a wise choice for allignment. Not a rip off like s13 powerflex either try to find pics if you want eibach front adj top mount kit is about £250, rear adj camber arms about £200
powerflex bushes that you need comes to about £70 but the whole kit is £190
Old 08-05-2008, 21:08   #7 (permalink)
turbo-tastic
Are these James springs worth buying?
BMW 320/323/325/328 E36 60/40mm Lowering Springs 120419 on eBay, also Suspension Components, Performance Tuning Parts, Car Tuning Styling, Cars, Parts Vehicles (end time 17-May-08 09:30:17 BST)
Bearing in mind about the rear camber issue, and its my daily hack, I dont want to go too mental.
Has anyone got any pics of E36 saloons that they know how much the car was lowered by??
Old 09-05-2008, 01:17   #8 (permalink)
neil a walker
BMW E36 E46 1992-05 318 323 325 328 M3 REAR CAMBER ARMS on eBay, also Suspension Components, Performance Tuning Parts, Car Tuning Styling, Cars, Parts Vehicles (end time 14-May-08 19:47:20 BST)
Dunno wot there like mate but at £75 maybe worth a shot??
(look a peice of piss to make anyway)
Springs maybe nice for daily driving, you will wanna give it sum shit now and then though, i had a 328 and was a lovely car with a nice suspension set up but was a bit posh for scruffy old me the diff is a really long ratio and spoils it a bit, but would definatly have one again, with a 325 ratio lsd in it
