Old 08-05-2008, 11:56   #1 (permalink)
swiftmini
cracked head! on a ca?
I think I maybe getting water transfer from my coolant port through to no.1 inlet port.
all the gaskets look mint and combustion chamber no.1 looks steam cleaned.
in my setup the only thing I have changed is the head. didn't steam with original head.
if I get it upto temp there is a fair amount of pressure in coolant hoses.
then if left over night the coolant header tank level drops about 10mm.
its not crap in the exhaust as I have removed it completely and the steam just comes out the turbo instead. i've bipassed the turbo aswell.
I just had the seats recut @ 3 angles and a clean up of the ports. £150
I don't know what to do!
crack and pressure test is £70
I could use old head and get my newly faced valves put in, may cost a small bit more than pressure test.
not sure.
cheers geezas
swiftmini is offline   Reply With Quote
Old 08-05-2008, 12:03   #2 (permalink)
David Reid
It could be head gasket although we had exactly the same thing on an sr20. As it built pressure it would produce steam from the exhaust and drop a cylinder.
Other than the steam it ran well on boost
When we got the head off it looked like one port/piston had been steam cleaned as you say. No obvious cracks and no sign of head gasket issues.
Cured it with a new engine
David Reid is offline   Reply With Quote
Old 08-05-2008, 12:28   #3 (permalink)
muttley
muttley's Avatar
Can you not buy/borrow/liberate a pressure tester
muttley is offline   Reply With Quote
Old 08-05-2008, 13:02   #4 (permalink)
swiftmini
yeah it runs bang on, it makes steam on overrun and kinda stops under boost, although I haven't really driven it above a few psi.
is it acceptable to make plate with a schrader valve and bolt it to the head so I can pressurise the port.
cheers
kev
Old 08-05-2008, 13:07   #5 (permalink)
GmasterT
talks alot
GmasterT's Avatar
I think I have a good Head available if you are interested
GmasterT is offline   Reply With Quote
Old 08-05-2008, 15:06   #6 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
Originally Posted by GmasterT View Post
I think I give good Head if you are interested
Old 23-05-2008, 06:24   #7 (permalink)
swiftmini
ohhhh matron!
problem solved with a headgasket, thanks for all input.
cheers
kev
