Old 08-05-2008, 21:23   #1 (permalink)
mattwelby
Wanabe Drifter
mattwelby's Avatar
Measurment
Can anyone help me with this measurment?
Basically from the back of the rear tyre to the front most part without a bumper on.
I've guessed by putting it at the front edge of the headlight covers.
Cheers
mattwelby is offline   Reply With Quote
Old 08-05-2008, 21:36   #2 (permalink)
niko
If you only need an approximate measure (not like millimetre-accuracy), you could use the axle-base as a reference and use the high-resolution picture to calculate it. Do it 5 times (or more) and you should be quite close.
Just an idea.
niko is offline   Reply With Quote
Old 08-05-2008, 22:20   #3 (permalink)
mattwelby
Wanabe Drifter
mattwelby's Avatar
Just an idea.
I was planning on cheating and getting someone else to do it lol. Will do that if i have to.
Cheers
Old 08-05-2008, 22:28   #4 (permalink)
Brunosr13
Brunosr13's Avatar
Cheers
check to you tomorrow
Brunosr13 is online now   Reply With Quote
Old 08-05-2008, 23:42   #5 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
You might want to specify the rear tyre size, 195/50/15s will give a different measurement to 255/40/18s.
SteveC200 is online now   Reply With Quote
